I'm going through baby videos, trying to minimize wasted time and space by trimming them. I see that Avidemux in copy mode is supposed to be lossless.
As a test, I opened and saved one video (no trimming) in copy mode, using the MPEG Ps muxer. According to what I see online this should give me a straight copy with no re-encoding, but the resulting file is slightly smaller than the original--16.2 MB vs 16.3.
Is this a true lossless copy or are my settings not correct?
TIA...
Different muxers, slightly different overhead. Your remux copy is lossless as far as the audio and video are concerned.
Don't forget to make your cuts on key-frames only....................
Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
racer-x, thanks for that info. I didn't know what those were until you mentioned it.
Trimming m2v files with MPEG video wizard
By BaPW in forum EditingReplies: 0Last Post: 11th Oct 2012, 14:30 -
avidemux audio sync problem with MPEG-2 - alt. way to cut mpeg-2
By graysky in forum LinuxReplies: 8Last Post: 6th Nov 2011, 21:02 -
Trimming with AVIDemux
By BobAchgill in forum EditingReplies: 10Last Post: 12th May 2010, 23:05 -
Lossless Video Clip Trimming
By azvenigo in forum Newbie / General discussionsReplies: 0Last Post: 9th Mar 2009, 23:01 -
Trimming an MPEG for DVD
By alhenderson in forum Authoring (DVD)Replies: 6Last Post: 9th Jan 2009, 13:58
