  1. I have really picky mp4 player that want every part of the audio and video channel to be exactly how he want them to be.
    The problem is I accidentally convert couple of videos in xvid as format and now they are not running.
    Can something be done to make them work without reconverting them again.
    The parameters of the working video are:
    Video
    Format                                   : MPEG-4 Visual
    Format profile                           : Simple@L3
    Format settings, BVOP                    : No
    Format settings, QPel                    : No
    Format settings, GMC                     : No warppoints
    Format settings, Matrix                  : Default (H.263)
    Codec ID                                 : XVID
    Codec ID/Hint                            : XviD
    Duration                                 : 21mn 34s
    Bit rate                                 : 200 Kbps
    Width                                    : 320 pixels
    Height                                   : 240 pixels
    Display aspect ratio                     : 4:3
    Frame rate                               : 15.000 fps
    Bits/(Pixel*Frame)                       : 0.173
    Stream size                              : 30.8 MiB (59%)
    Writing library                          : XviD 64
    And the parameters of not working videos are:
    Video
    Format                                   : xvid
    Codec ID                                 : xvid
    Duration                                 : 23mn 57s
    Bit rate                                 : 200 Kbps
    Width                                    : 320 pixels
    Height                                   : 240 pixels
    Bits/(Pixel*Frame)                       : 0.174
    Stream size                              : 34.3 MiB (59%)
    The audio channel is ok.
    Edit:I fix the videos with FourCC Code Changer
    Try fourcc code changer.
    (Just posting a link to it...)
