Hi. I am converting my family's memories onto my computer. I bought a used Sony CCD-TR400 Hi8 Handycam. Everything was working fine. (I am also using Elgato video capture into my iMac.) I came across a tape that seemed to have nothing on it. Then another. Sometimes they play just a blank, black screen, other times snowy static. But the timecode is moving so I know somethings there. After a third one, I thought something was wrong, so I went back to one of the tapes I had successfully transferred. (I transferred five but have 13 more to go.) That one didn't play, again, just snow. Or black. Even though it had already played it.
So, I put in a new tape in the camera and recorded with it. And played it back. Everything seems fine.
Well, of the tapes that I had already transferred, only the LAST one I successfully did will not play back.
However, none of my yet to be done 13 will play, either.
I can't believe they are all bad or in any way corrupted, but if that tape caused an issue with the camera, how can that record and play. Or play the other 4 tapes that I transferred already?
BTW, I did try to re-set the camera to its factory default with advice from a Sony tech. Nothin'.
Any ideas on what's going on? Solutions? Help! (I can't afford to pay to have 13 tapes transferred.)
Can you try another cam with the problem tapes - perhaps at a used camera store?
Best Sony Digital8 Camera to convert 8mm/Hi8 to PC?
By Optical in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 30Last Post: 7th Oct 2017, 12:34 -
what camera to read Hi8 tapes into PC?
By wildbill001 in forum Video ConversionReplies: 7Last Post: 6th Dec 2013, 20:27 -
Hi8 camera with mono - s-vodeo out but with stereo pre recorded tapes
By ozstar100 in forum RestorationReplies: 5Last Post: 29th May 2013, 23:42 -
AviDemux Odd Problem
By gonwk in forum Newbie / General discussionsReplies: 4Last Post: 3rd May 2013, 18:12 -
Sony Hi8 has been defective but want to play the Hi8 tape
By coody in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 16Last Post: 22nd May 2009, 23:06
