  1. I have a high speed video camera (Edgertronic).I produced a nice video clip: http://www.youtube.com/watch?v=OL8xwX0QUCA
    Now I want to speed up part of the video, and keep the rest at the current speed.
    So I've installed VirtualDubMod and separated the two pieces...
    a=avisource("untitled.avi").trim(1,124)# comment
    #assumefps(100)
    b=avisource("untitled.avi").trim(125,1196)# comment
    video=a+b
    video
    The above works fine, but of course it doesn't DO anything, other than separate the two pieces and then play them back as one..
    What code would I have to add (keep it simple, please) to speed up the first part.
    Say, by a factor of 6.
    I know there is assumefps, changefps, but I can't seem to get the syntax right.
    I am not fussy about getting this perfect the first time.
    I could select every 6th frame, or blend frames, whatever.
    Would appreciate it if someone could suggest exact changes to the above, so I have a starting point for experimentation.
    Thanks a lot.
    Alan Wolf
  2. a=avisource("untitled.avi").trim(1,124)# comment
    a=a.SelectEvery(6).AssumeFPS(a.framerate)
    video=a+b
    video
  3. Member racer-x's Avatar
    Mar 2003
    3rd Rock from the Sun
    I don't use VirtualdubMod, but I assume it's using something like Avisynth scripts. So if you are using 30 fps source and want to speed up the first part by 6x, then you may want to use something like this:
    a=avisource("untitled.avi").trim(1,124).assumefps( 180).changeFPS(30)
    b=avisource("untitled.avi").assumeFPS(30).trim(125 ,1196)# comment
    video=a+b
    video
  4. Thanks! Worked great!(Both of them.)
