How in the world to you bypass Ciniva protection on DVD and Blu-Ray? Kick-Ass 2 has it on the DVD as well as on BD.
Results 1 to 21 of 21
Most of the techniques people have found to eliminate Cinavia detection leave the audio so badly distorted you won't be able to stand listening to it.
https://forum.videohelp.com/threads/353091-How-to-remove-Cinavia-protection?highlight=cinavia
But apparently a one semitone pitch change is sufficient. You may find that bearable. -
Do foreign released BR's use Cinavia? I see Kick Ass 2 has been released in the UK.
With all this hysteria over Cinavia, I would imagine older Cinavia detection free Blu-Ray players gain in value. I wonder how much my old Panasonic Blu-Ray player might be worth on Fleebay.
Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
Aren't the front USB jacks on BR players currently Cinavia free?
Truly...I have.
Alternative playback methods:
1) HTPC
2) Media player (like the WD_TV Live).
3) If your TV is recent and has an onboard media player, it probably supports H.264 in MKV. Convert/repackage your backups accordingly and hook up an external powered hard drive (2 TB limit) via USB to the TV.
I use both 1 and 3.
Damn, now I'm wondering what my (2) Sony standalones are worth. BDP-S-360s, lightly-used, and Cinavia free.
I haven't used either in more than a year.Pull! Bang! Darn! -
I'v seen some of the older cinavia free players go for alot of money especially the Oppo players, I personnelly would rather have my back-ups on a disk then on a hard drive, From what I read there has only been 11 DVDS containing cinavia protection since 2011, Hopefully someone will soon have a fix for us die hard fans.
A lot more than that. This list has about 160 titles: http://blog.dvdfab.com/cinavia-protection.html
Not sure where you are in the world, but if it is the US (or possibly UK). Couldn't you just go into a normal store and buy a sort of no name brand cheapie dvd player, since the odds are very unlikely it would support Cinavia.
Most (well some) newer dvds are having it applied because the companies also know that most will use a bluray player rather than a dvd deck to play burned dvd backups on and they want a stop for that -
they haven't, but if any major brands are still making them there could be a slim chance of it sneaking into decks. However the original poster only mentioned a bluray player (well he mentioned a dvd and bluray but since he saw Cinavia on the dvd it tells me he is using a blu player only) which is why I suggested then to just get a normal dvd deck if he wants to view the dvd film he mentioned (Kick ass 2) without any problem
Or it means he made a burn for someone else and they are having an issue for the same reasons I mentioned.
either way it results in just getting a dvd deck only -
jagabo, http://blog.dvdfab.com/cinavia-protection.html, That's where I got my information, I only mention the DVDS with cinavia protection because I wanted the OP to be aware of that information, But your standard DVD player should play those DVDS that have cinavia with no problem.
What I'm trying to get an understanding of is what actually triggers Cinavia? If I'm making a backup of a full BD, without re-encoding anything, why is the protection being triggered? Is it simply that if Cinavia is detected and the disk used is recordable, then the protection triggers?
^ When you make your backup, you are removing the AACS encryption. Cinavia is a watermark in the audio, which is detected almost immediately, then the detection routine checks to see if this encryption is present.
From Wikipedia: The Blu-ray Disc implementation of Cinavia is designed to cover two use-cases: the first is the provision of a Cinavia watermark on all movie theater soundtracks released via film distribution networks; the second use-case is for the provision of a Cinavia watermark on all Blu-ray Disc releases that points to the presence of an accompanying AACS key. If a "theatrical release" watermark is detected in a consumer Blu-ray Disc audio track, the accompanying video is deemed to have been sourced from a "cam" recording. If the "AACS watermark" is present in the audio tracks, but no accompanying and matching AACS key is found on the disc, then it is deemed to have been a "rip" made by copying to a second blank Blu-ray Disc.
Some Blu-ray players (hardware and software) will detect Cinavia in various types of media files and stop playback at the 20 minute mark every time. Some others only seem to detect Cinavia when played from a disc, and not from usb sticks or files on a hard drive. I generally test for Cinavia using TMT 6 and it honors the Cinavia flag from everything. -
USB-Cinavia
By wulf109 in forum Blu-ray RippingReplies: 1Last Post: 9th Dec 2013, 13:27 -
Just A Thought - Cinavia
By teesimmons14k in forum Video ConversionReplies: 16Last Post: 23rd Oct 2013, 10:12 -
After Earth has Cinavia
By wulf109 in forum Blu-ray RippingReplies: 26Last Post: 16th Oct 2013, 23:33 -
cinavia in 2in1
By asiafan in forum Authoring (Blu-ray)Replies: 11Last Post: 29th Jun 2013, 18:20 -
Does The Three Muskteers use Cinavia?
By wulf109 in forum Blu-ray RippingReplies: 33Last Post: 18th Mar 2012, 11:56
