How can you find out whether a certain AVI file is NTSC or PAL?
You could check out by the by the size of the frame and it's rate. If It's ***x388 or ***x576 and with a frame rate of 25 fps than it's PAL. If itīs ***x340 or ***x480 than with a frame rate of 29,97fps or 30fps it's NTSC. You may find 24fps or 23,976fps this is film frame rate.
t0nito,
Just a small correction there, I believe it should say ***x352 instead !?
...or you can just take a look here: http://www.vcdhelp.com/vcd.htm
Hope that can help you CFCboy...
Regards,
John Brondum -
No. Actualy I meant ***x288 but instead I wrote ***x388. Oops. Sorry. Thanks for noticing anyway!
25 PAL to 23.976 NTSC AVI
By Nedward Orton in forum Video ConversionReplies: 8Last Post: 24th Mar 2012, 09:56 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 12:57 -
Is this AVI PAL or NTSC?
By RedPenguin in forum Video ConversionReplies: 6Last Post: 25th Feb 2011, 21:17 -
NTSC(?) avi to PAL dvd
By Instant Martian in forum Video ConversionReplies: 34Last Post: 14th Mar 2009, 15:32 -
PAL , NTSC in AVI
By anirban in forum Newbie / General discussionsReplies: 2Last Post: 3rd Nov 2008, 06:28
