I have some VOB files i want to burn but how do i make the IFO and BUP files is there some software that will look at my VOB file and make the necessary i need so i can just burn a disc then using Ashampoo.
cheers
I'm pretty sure avs2dvd should be able to reauthor it for you. Without reconverting. Add the vob files and it should take a few seconds/minutes to output it.
Or else use other dvd authoring tools like dvd styler, dvdauthorgui, guifordvdauthor, muxman(only demuxed video and audio streams).
Is it possible to convert VOB files to AVI files?
By Sulli in forum Newbie / General discussionsReplies: 14Last Post: 14th Oct 2012, 01:01 -
burning DVD from either .VOB or .mp4 files
By rosmari in forum DVD RippingReplies: 6Last Post: 16th Apr 2012, 12:56 -
Burning VOB files to DVD WITHOUT Menus Or Chapters
By mediachimp in forum Authoring (DVD)Replies: 5Last Post: 11th Aug 2010, 02:11 -
Save Rendering Time--Change VOB to MPG--Set Audio VOB & MPG2 video files
By jake61 in forum Newbie / General discussionsReplies: 4Last Post: 5th May 2010, 16:12 -
Burning DVD's after converting to .vob files
By Joyful Noise in forum Newbie / General discussionsReplies: 1Last Post: 7th Mar 2010, 00:37
