Is there any AUTOMATIC converter program/site/way that support Greek language and can convert any sup file into srt file?
If there is can you tell me what is that?
And if it doesn't is there any program that it doesn't need to create greek dictionary for every subtitle.
A LOT OF THANKS.
Results 1 to 9 of 9
Nope,you have asked this question in other threads,time to give up.
Since it appears you're having problems with OCR (I don't know why you need SRT) a suggetion:
- Mux your SUP file into the video file with MKVMergeGUI
- Hardcode the subtitles with MediaCoder using "Vobsub render" on the Subtitle tab.
- Start by selecting a couple of minutes on the "Time" tab for testing -
I know how i can merge the pgs/sup subtitle into any mkv file with mkvtoolnix program but the media player i use DOESN'T support pgs or sup so i want a program that i can convert pgs/sup file into srt.
And the way you suggest i don't believe it does do that.
thanks for your time. -
Well, it looks somewhat like this
https://www.youtube.com/watch?v=vV45JG0M27g&feature=youtu.be
And in english
Code:1 00:00:01,000 --> 00:00:04,000 This is Google translated Greek from English 2 00:00:04,024 --> 00:00:07,024 so it may be somewhat funny 3 00:00:07,048 --> 00:00:10,048 The Greek subtitles are exported from Subtitle Edit as BD SUP 4 00:00:10,072 --> 00:00:12,072 and muxed into a MKV container 5 00:00:12,096 --> 00:00:14,096 Then they are hardcoded with MediaCoder
As i tallied you before my media player DOESN'T support sup or pgs subtitles either it was hardcoded at movie either external so....
Already do the 1st bluray disc of hobbit 2 3d and here is the specifications:
General
Complete name : D:\Downloads\Hobbit2 3d disc1.m2ts
Format : BDAV
Format/Info : Blu-ray Video
File size : 21.1 GiB
Duration : 1h 15mn
Overall bit rate : 40.3 Mbps
Maximum Overall bit rate : 35.5 Mbps
Video #1
Menu ID : 1 (0x1)
Format : AVC
Format profile : Stereo High@L4.1
MultiView_Count : 2
Format settings, CABAC : Yes
Format settings, ReFrames : 2 frames
Codec ID : 32
Duration : 1h 15mn
Bit rate mode : Variable
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Video #2
Menu ID : 1 (0x1)
Format : AVC
Format profile : High@L4.1
Codec ID : 27
Duration : 1h 15mn
Color space : YUV
Bit depth : 8 bits
Audio
Menu ID : 1 (0x1)
Format : DTS
Format/Info : Digital Theater Systems
Mode : 16
Format settings, Endianness : Big
Codec ID : 130
Duration : 1h 15mn
Bit rate mode : Constant
Bit rate : 1 509 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 24 bits
Compression mode : Lossy
Stream size : 811 MiB (4%)
Language : English
Text
Menu ID : 1 (0x1)
Format : PGS
Codec ID : 144
Language : GreekLast edited by fits79; 23rd Apr 2014 at 07:49.
When it's hardcoded it becomes part of the video. You can't watch the video without seeing the subtitles when they are hardcoded.
Yes but if it need some hours for every movie to make the gr subs hardcoded into the movie file it isn't accepatable.
I want to do the srt file into some minutes NOT in some hours and if hardcoded the full movie it gonna make it a lot of hours so is useless...
neither or less thanks for your help.
Edit: tell me the exact newbie guide to make it hardcoded gr subs into the movie file so i test it how many time it do for full movie and if it is lower than 1 hour maybe i do it that way.
Edit2: No my friend it take TOOOOOOO long.
For 10 minutes sample it took me 15 minutes so imagine for 1 and more hour movie....Last edited by fits79; 23rd Apr 2014 at 08:02.
Convert SRT to SUP?
By lazyturbo in forum SubtitleReplies: 14Last Post: 28th Dec 2022, 13:05 -
how to convert .sup to .srt
By akakiami in forum SubtitleReplies: 20Last Post: 13th Jan 2018, 10:53 -
I want convert srt to sup
By mmkk in forum SubtitleReplies: 5Last Post: 16th Aug 2013, 09:50 -
A better way to convert sub to srt files
By carlmart in forum DVD RippingReplies: 3Last Post: 22nd Mar 2013, 16:53 -
How to demux .srt from mkv, then convert .srt to .smi and mux .smi to mkv??
By narayanan in forum SubtitleReplies: 1Last Post: 7th Aug 2010, 22:49
