Hello to all and Happy New Year! I have a problem: I have a video that plays but every few seconds it slows up and then goes back to normal. Is there anyway to fix this problem and do you need a sample. I would greatly appreciate the help. Thanks!
Results 1 to 16 of 16
I play it on the computer with vlc and also on Windows media player. I burnt it to a disc but I have the same problem.
Here is the sample:
https://www.mediafire.com/?lmm0ao1av5dl4k3 -
No problems for me playing,it's been encoded incorrectly with interlacing and poor quality.
What d you mean it slows down?
The audio and video together, or does one get ahead/behind the other?
I took a look at the second sample, and except for some occasional stuttering n the audio (at 18 seconds in)
I don't really see anything else. -
There's nothing wrong with how it plays, except for the audio glitch davexnet mentioned.
If you're making a DVD the interlacing is fine, otherwise not. You have a much bigger problem. The blacks are horribly crushed and much of the damage can't be fixed. Also it's blocky as hell because you used much too low of a bitrate. Better would be for you to begin again with the capture, if that's what this is, because, as johns0 said, this is a very poor quality video. -
How do I solve the stuttering in the audio? Thats the only problem I have with this video.I would greatly appreciate the help
Why bother? There's much more wrong with it than a slight audio glitch.
Then why this thread about a 'lagging problem'?Thats the only problem I have with this video.
If you captured it from TV or a tape or someplace else, then do it over again. If you downloaded this garbage from somewhere then delete it.How would you start a capture? -
probably this was recorded using a cell phone, compact camera or tablet?Since garbage-in, garbage-out, see if you are fine with the following...(audio not fixed, just the video)
For the audio, I do not know any fix but you may choose to mute/fade-out the problem parts(extract the audio stream and load into Audacity for the editing.) -
Video/sound out of sync and lagging on pc
By keaze in forum Newbie / General discussionsReplies: 3Last Post: 15th Mar 2012, 23:09 -
HD Cam Keep lagging
By Okay in forum Newbie / General discussionsReplies: 3Last Post: 9th Oct 2011, 12:55 -
EasyCAP w/ Ulead and Pinnacle - Video Stuttering/Jumping/Lagging problem
By Logan289 in forum Capturing and VCRReplies: 0Last Post: 30th May 2010, 15:25 -
VLC media player lagging video
By Obamargarine in forum Software PlayingReplies: 4Last Post: 19th May 2009, 22:36 -
Adobe Premiere 2.0 Video Lagging! But Why?
By daiweb in forum Video Streaming DownloadingReplies: 2Last Post: 19th May 2009, 10:13
