HI, i recently downloaded the LOTR screened dvd rip from Kazaa, 700 meg each part. Anyway it's 640x272. I tried encoding in with tmpenc but when i play it i get a messed up image.
it's got the movie on one half of my tv and green/black lines on the other, I have a panasonic Rv31k i think. When i play it in 4:3 or letterbox i get the same thing HELP anyone
Results 1 to 11 of 11
I think I may have the same AVI. When I try to convert it to mpeg using TMPEGenc, for putting on a VCD, I get the video just fine but no audio. I do a simple de-multiplex of the mpeg file and it shows via the file size that it HAS encoded an audio file, but I sure can't figure out why it won't playback. The audio is 48khz mpeg 2.
Stratz999:
To fix the resolution, make an avisynth script with bicubicresize to change the format to 325x240 or whatever NTSC is supposed to be.
Trailryder:
Maybe it's AC3 audio? You will have to convert it to mp2 and do a downmix to surround and downsample to 44100 hz if that is the case. -
Did you guys figure out how to convert this thing correctly yet? I have the same files and have had no luck with it either. I am trying to convert each file to MPEG2 so I can burn both of them onto a single 4.7gig DVD. But When I use TMPEG encoder, I just get a black screen. Can't seem to get around it. If you guys could post your exact steps you took that would be very cool.
Jakobud -
Just an FYI, there is a VCD/MPG format floating around. I haven't looked on Kazaa but I did find it a couple of months ago using Direct Connect. The files were 'Lord of the Rings CD1.mpg' or something like that (3 cd's total). I just burned them without converting and they play fine on my Apex.
Hi All
I think I've got the same Avi's. They are in DivX format and I made a perfect DVD-R from it. Even with Dolby Surround AC3 Sound.
The How To is to long for this Reply, but e-mail me for a Word Or PDF file. Please mention the Word version you are using. -
hi when im trying to make de mpeg-2 and putting the subtitles
i get the subs ok but the movie goes like playing and pausing constantly
what can i do -
I think this is the Centropy version. The four disc SVCD version is known as the TCF one.Originally Posted by DVantrease
Hi there,
I found that the word file was 3,5 Mgb big. So I created a link on mine WebPage. You can find it here. http://www.epiphany.nl
GrEEtZ
Where can I buy those foam rings on DVD spindles?
By nathanaa in forum Newbie / General discussionsReplies: 11Last Post: 23rd Nov 2017, 09:49 -
Why are cdr burn rings lighter than dvdr burn rings?
By yoda313 in forum Newbie / General discussionsReplies: 4Last Post: 27th May 2010, 18:55 -
lord of the rings Extended Editions? need very high quality rips
By dave_o in forum DVD RippingReplies: 3Last Post: 28th Jan 2010, 12:43 -
Lord Of The Rings (Extendet Edition) Demux - Remux Probs
By Summersun78 in forum Authoring (DVD)Replies: 3Last Post: 14th Nov 2009, 08:15 -
Question about zone burning rings on DVD
By jimdagys in forum Authoring (DVD)Replies: 3Last Post: 30th Dec 2008, 17:24
