If you don't like the version of Windows Paint that comes with W7 or W8, you can easily add the older XP version of the mspaint program to your PC. Mspaint is a .exe program file, so no install needed. If you have a copy of XP, the older version of paint is in 'C/Windows/System32/mspaint.exe". Copy and paste to W7/W8 where you want, then pin it to the start menu. Or if you don't have XP, you can find the XP mspaint on the net.
One location ' http://www.sheeptech.com/download/mspaint.exe ' (Lclick and save where you want, and then Rclick on the program and select 'Pin to Start Menu' so you will have easy access.) You could also replace the original file in the W7/W8 Windows folder, but you need permissions. This would allow the XP paint to show up in context menus.
I don't use Wordpad, but in XP it's in 'C/Program Files/WindowsNT/Accessories/Wordpad.exe' It runs on W7/W8, but I'm not sure if it's fully functional. If so, you could copy it also to your newer PC.
Results 31 to 32 of 32
Greeting Redwudz .....
Carefully re-read my previous post (B-4 yours). All will be explained there.
Thanx-A-Lot, Frank-0-VideoTHE Ultimate TV Tuner Device - Picks up every broadcast-cable-satellite transmission since 1928!
Can Win Update Items Trash Your Computer (?)
By Seeker47 in forum ComputerReplies: 18Last Post: 28th Nov 2013, 15:53 -
subtitles to 3D - Can someone confirm this is right please
By mattyninegrand in forum SubtitleReplies: 34Last Post: 11th Nov 2012, 13:53 -
Inferiority complex - confirm/deny
By john4100 in forum Newbie / General discussionsReplies: 8Last Post: 2nd Jun 2012, 14:12 -
Sharp Mini DV firewire not detected by Win 7 but was working under Win XP.
By thintin in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 6th Jun 2010, 03:12 -
Win 7 and XP dual boot issues. Can't access one of the drives in Win 7?
By Denvers Dawgs in forum ComputerReplies: 3Last Post: 13th Jun 2009, 23:51
