I'm looking into purchasing one of these..and was curious if I should even try. The system requirements are dual core and 2.0 ghz. My laptop has a dual-core processor but it's only 1.6ghz. Will these still capture and work ok? Or should I try to find something different to capture games? I don't wanna spend money..and it not work. Anyone tried something slower than a 2.0?
				Results 1 to 9 of 9
	Both of these can capture without a PC.
 http://www.avermedia-usa.com/AVerTV/product/ProductDetail.aspx?Id=519
 http://www.avermedia-usa.com/AVerTV/product/ProductDetail.aspx?Id=518
	I'm looking for a retro game capture device also..not sure if those would work.
	Elgato will not run on your laptop (maybe for standard definition but definitely not for HD). The Hauppauge will work but you may not be able to use their software to view the video while capturing. You could use GraphEdit to build a capture graph that simply routes the incoming compressed A/V stream it writes it to a TS file.
 https://forum.videohelp.com/threads/355970-hauppauge-hdpvr-1212-and-graphedit?p=2240930...=1#post2240930
 With that you'll probably only see single digit CPU usage while capturing.
	The Avermedia Live Gamer Portable (linked to by zapster) can work as a standalone device and record directly to an SD card.
	Elgato will even capture from older consoles which were pre 480i ... snes, commodore 128, sega ... its your best choice.
 Like all things of the past, support drops off eventually.
 Consider if your into purchasing one of these, if budget allows, you can pickup a system which exceeds the pc requirements out of ebay for around the same price as the capture device ... a dell e8400 + win7 generally goes for around $200.00.
 And welcome to the forum Kous52
  Why my Elgato game capture hd is lag ?By Chocolade in forum Capturing and VCRReplies: 2Last Post: 21st Nov 2013, 19:44
  Any way to use two microphones with the Elgato Game Capture?By Vic 2.0 in forum Capturing and VCRReplies: 27Last Post: 11th Nov 2013, 13:22
  Elgato Game Capture or HD PVR 2 ???By gizmu in forum Capturing and VCRReplies: 24Last Post: 26th Oct 2013, 18:25
  Is there any way? (Elgato Game Capture HD)By Vic 2.0 in forum Capturing and VCRReplies: 1Last Post: 12th Jul 2013, 17:49
  Help with Elgato Game Capture HD!By Nesoroth in forum Capturing and VCRReplies: 1Last Post: 28th Jun 2012, 13:26
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
