i can't download or capture this stream on this site
http://www.3sat.de/mediathek/?mode=play&obj=40430
won't even load the page in tubedigger.any help is welcome and thanks in advance
http://www.3sat.de/mediaplayer/11/configuration_player3_live_jshybrid2.xml
http://vqm.zdf.de/conf/zdfplayer/1.2/3sat/vqm.xml
Not sure if I understand you. But I will go through the whole process.
1. Select record mode not download mode. (Download mode may work but I did not test it)
2. Move the bit-rate selector off the video screen and click cancel.
3. Stop the recording when you are ready - if downlaod works it should stop on its own.
4. The recorded stream has a timing issue (quite common) so you must convert it.
5. Click convert. Select your saved .flv. Check the 'fix flv' box and then click 'convert'. The file will then be quickly remuxed into a .mp4 and will play. -
This is AdobeHDS f4f format. Download it with Tubedigger (v4.6.3 tested in 'Rec+' mode) or AdobeHDS.php [tutorial].
Download/Capture trailers from Itunes store?
By digitalfreaknyc in forum Video Streaming DownloadingReplies: 24Last Post: 14th Oct 2020, 15:42 -
I cannot download a stream Capture
By neroman00 in forum Video Streaming DownloadingReplies: 12Last Post: 28th Jan 2013, 07:03 -
Download Youtube video with multiple audio tracks?
By SimmianPrime in forum Video Streaming DownloadingReplies: 6Last Post: 1st Sep 2012, 11:33 -
Video Capture issue Only mono audio on s-video - composite adapter :(
By techspark in forum Capturing and VCRReplies: 47Last Post: 13th May 2012, 19:09 -
Audio hum during video capture...help.
By daysaf00 in forum Capturing and VCRReplies: 16Last Post: 27th Jan 2012, 21:04
