I run a media server, XBMC, and I have Invader ZIM on DVD, and would like to rip to MP4's, around 175MB per file if possible.
What setting would be good to use?
For example... I noticed that the storage resolution is 720x480 and it's viewed at 640x480. Leave that as is? or just make the storage resolution and display the same? I'd like to trim off about 4px off the left and right side (black strip) and having the display/storage the same resolution makes sense to me, but, might be an advantage of having the storage as 720 wide?
Also, I want to avoid those horizontal lines/streaks... interlacing?
Also having issues figuring out where one episode starts and another ends, not sure if any tricks for that at all.
Just wondered if anyone had a good basic setup for cartoon rips, or, if there is another program with a user friendly GUI I should use instead. Thanks.
				Results 1 to 1 of 1
  Vidcoder preset helpBy TriggerThumb in forum Newbie / General discussionsReplies: 9Last Post: 17th Dec 2013, 17:00
  Help with Vidcoder and suptitlesBy jerecho in forum Video ConversionReplies: 4Last Post: 31st Oct 2013, 23:38
  Vidcoder Not WorkingBy wulf109 in forum Blu-ray RippingReplies: 1Last Post: 12th Jun 2013, 09:56
  Vidcoder setupBy carlmart in forum Video ConversionReplies: 41Last Post: 21st Mar 2013, 09:17
  Ripping Single Episodes of Cartoons for Re-Authoring - JaggiesBy jdmba in forum DVD RippingReplies: 7Last Post: 5th Aug 2009, 14:19
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
