I live in Nova Scotia Canada and have purchased DVDs from Amazon.com and they will not play on my present LG DP530 (it says that it will not play the region B) I would like for someone to tell me exactly what DVD player will play all regions from 1-6 and ABC ALSO Blue-Ray/ 3D/ Have checked by searching and fount nothing to lead me in getting the right machine for my needs. Thanks for your help.
Results 1 to 20 of 20
Well you hardly looked very far.
http://www.amazon.com/Sony-BDP-S5100E-Worldwide-Voltage-Included/dp/B00CS5HAG2/ref=sr_...blu+ray+player
But why oh why is your current player Region B ? -
It is not Region B it tells me that I cannot play the region B DVD that I had purchased fro Amazon.com
Amazon.ca lists the same Sony player: http://www.amazon.ca/BDP-S5100-Multi-Region-Player-2-4Ghz/dp/B00C1L8QZ2/ref=sr_1_1?ie=...blu-ray+player
It also lists a region-free version of the LG BP 530: http://www.amazon.ca/BP530-International-100~240V-Voltage-Included/dp/B00CP8BUQI/ref=s...layer+LG+DP530
Note that these players have undergone hardware modifications and may be running custom firmware. It isn't possible to make the normal versions of these players region free yourself. -
Region B is for blu ray not DVD. I suppose Amazon.com sell imported (from Europe etc.) blu rays but the alarm bells should ring.
The player I linked to should play them. But your tv might not display them. -
Yes, it is a good idea to contact the seller to find out for certain if these players will convert "PAL" resolutions and frame rates for a N. American TV. They probably do, the LG is even described as converting, but you wouldn't want to find out that they don't after buying them.
Tried to purchase the Sony-BDP S5100E DVD player and Amazon told me this (We're sorry. This item can't be shipped to your selected destination. You may either change the shipping address or delete the item from your order.) They sold me DVDs that I cannot play on my present DVD player so what would be my problem. Something seems to be wrong They sold me DVDs that will not play on my present DVD player but will not sell me a DVD player that is suppose to play that type of DVDs.
I tryed to make the purchase again and it will not accept the purchase.
Why do you insist on calling these DVD's. ?
Just use usually_quiet's link and buy from Amazon_Canada.
Surely they (Canada) will ship to you. No idea why they(US) do not ship to Canada but they may be import restrictions for higher value items. Just a guess. -
Reply to all that was so willing to help me I finally placed my order through wwwamazon.ca don't know why i had problem with wwwAmazon .com Thank you all so very much fro your professional help. THANKS !!!!!!!!!!
Is it not DVDs. As you can see I haven't a clue with all these electronic terms what are the disks actually called. Thanks once again.
Amazon.com does ship to Canada.
If you type Amazon.com into your browser, chances are you were re-directed to Amazon.ca -
DB83's link in post #2 does say that Currently, item can be shipped only within the U.S.
Ok get you on ABC blue-Ray and DVDs zones . I always thought that it was CDs and DVDs found out something new Thanks DB83 very much also clockwork and usually-quiet.
Blu-Ray player that can play all regions of DVD?
By Jeikobu in forum DVD & Blu-ray PlayersReplies: 4Last Post: 26th Oct 2012, 09:29 -
Blue-Ray DVD Player Philips BDP3100 unlock Subtitles code
By shalevagr in forum Authoring (Blu-ray)Replies: 10Last Post: 19th Jul 2011, 03:50 -
unable to see DVD's burned on my computer on the new Blue ray player.
By kindrob in forum Newbie / General discussionsReplies: 26Last Post: 8th Dec 2010, 02:49 -
Purchasing blu-ray player: Wondering if my system is perhaps too old for it
By toaster_pimp in forum Newbie / General discussionsReplies: 6Last Post: 20th Aug 2010, 17:15 -
New NON-Blue-Ray DVD Player or better off with WDTV Live HD Network Media?
By tigerb in forum Newbie / General discussionsReplies: 0Last Post: 3rd Nov 2009, 12:36
