Hello all, nice to meet you!
video produced from my Nikon D5100 is mov with LPCM audio, which is useless for any media player I tried, including WDTV: video plays fine but the audio band does not. I naturally want to convert these videos in a lossless manner. The path I discovered is the following:
1. use a program like TAudioConverter to extract the audio and convert it to a separate mp3 file.
2. use mkvmergeGUI to create an MKV merging the video band from the .mov and the mp3 file.
Usually works just fine, and quality is retained 100%! However, I tried a larger .mov yesterday (around 1,5GB) and mkvmergGUI failed with "return code 3". I don't know whether it is because of the larger size, or something else. In any case, my question is the following: do you know of any alternative to mkvmergeGUI for this kind of job? Basically, creating mkv from various parts without re-encoding.
Thank you.
Try ffmpeg or gui for it like xmedia recode. You load the mov. Select format mkv. Under video choose copy stream. Under audio mp3 or aac.
Or from command line
ffmpeg -i video.mov -vcodec copy -acodec libmp3lame -ab 192k video.mkv -
several encoders have "pass through" where either the video or audio is left unchanged while re-encoding the other. you could try avvidemux, mediacoder, xmediarecode and others i can't recall at the moment.
Convert flac or wav to lpcm
By wiseant in forum AudioReplies: 7Last Post: 30th May 2012, 19:02 -
Help! How to convert mpeg-2 file with LPCM audio to Final Cut Pro?
By afireinside181 in forum Video ConversionReplies: 3Last Post: 31st Oct 2011, 19:59 -
how to convert mp2 audio to lpcm?
By gareth41 in forum Authoring (Blu-ray)Replies: 9Last Post: 21st Oct 2011, 14:47 -
Need Help Converting Audio 44.1KHz LPCM flac to 48KHz LPCM + Add to DVD
By nagysaudio in forum AudioReplies: 2Last Post: 5th Oct 2010, 10:15 -
Convert DTS stream to LPCM ??
By Browncoat in forum AudioReplies: 9Last Post: 1st Oct 2009, 17:48
