I bought the SM Supervision 2500 two weeks ago because I have heard, that it plays SVCDs in good quality.
I created some SVCD with different Software on my Computer and tried to play them with the Supervision 2500, but it didn't work as it should.
The player accepted the disc, but it didn't play the video fluently (the sound was okay, there were problems only with the picture).
I tried SVCDs with other bitrates, which worked better, but every ten seconds the video stopped for a short moment.
I have no idea what could be the problem, so can anybody help me?
:roll: I'm sorry for eventual mistakes, but I'm not from an English speaking country, so please forgive me...
I own a SM Supervision 2100 and it's working O.K. (I supose 2500 as well)with SVCD's so you should try another burning softw. or encoder. Btw. which prog's are you using ?
I used the Ulead Media Studio Pro 6.5 and DaVideo professional to create the SVCD files. Then I used Nero 5.5, to make a CD.
They haven't worked for me, the first time either. I'm sure you will find the way. . . First, it sounds like a high bitrate problem, try using lower bitrates on CD-RW. Another aspect i've found related to this player, it will NOT play any file under 20 MB. I advise you try a bigger file for experiments ( at least 50 Megs ). Always make sure the files play O.K. on the computer ! Hope this will help.
Need BluRay player that does what Philips 2500/2700 does,but sells in USA
By ufcdave in forum DVD & Blu-ray PlayersReplies: 2Last Post: 22nd Feb 2011, 21:41 -
Please help! New DVD player doesn't work :(
By confuzedinTN in forum DVD & Blu-ray PlayersReplies: 3Last Post: 20th Sep 2010, 13:44 -
Subs work on PC/VLC Player...but don't show up on dvd player
By bgart13 in forum SubtitleReplies: 9Last Post: 22nd Aug 2009, 18:06 -
how can i make sure my dvd will work in any player?
By el_nex in forum Newbie / General discussionsReplies: 6Last Post: 6th May 2009, 17:22 -
Cannot figure out which dvd player will work.
By capman21 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 26th Mar 2008, 10:04
