Unfortunately I can only change few things inside my BIOS. I tried a pre-LAV version (1.5.1.2903), but got bad results.
That weird resolution is due to the fact that I widened the player in order to show all the stats given by Ctrl+J. Besides, that sample (that I recorded with Fraps) was just supposed to show you the kind of stuttering I'm experiencing.
After trying the ffdshow filters over the LAV ones, I also wanted to try the Haali Media Splitter over the LAV Splitter, but couldn't get MPC-HC to use Haali. I first preferred Haali inside the Codec Tweak Tool, then set it to "Prefer" inside the "External filters" section of MPC-HC and then tried to tinker with the merit system, but to no avail.
After that I decided to get rid of the K-Lite Codec Pack and installed the standalone version of MPC-HC. Since I couldn't see any improvement, I then installed the Haali and ffdshow packages, but again that didn't make any difference so I guess the conflict is not among codecs and filters. Right now I'm still trying to get MPC-HC to use the Haali Media Splitter.
OT: is it just me or the forum doesn't let you multi-quote?
Results 31 to 32 of 32
Sorry for necroposting but after years I happily found a simple and working solution that is enabling D3D Fullscreen in MPC-HC. Options → Output → Check "D3D Fullscreen". You will lose the GUI controls when you go full screen, but you'll be able to play anything silky smooth at least to the human eye. Have a good day.
Video stutters when deinterlaced an when played in a DVD player
By Kado in forum Video ConversionReplies: 17Last Post: 13th Aug 2010, 13:03 -
video and audio stutters in quicktime
By lskwarek in forum Newbie / General discussionsReplies: 3Last Post: 9th Jun 2010, 13:26 -
Video Stutters after windows 7 upgrade
By Habby in forum ComputerReplies: 5Last Post: 10th Mar 2010, 21:56 -
Blu ray conversion to mkv stutters, audio ok but video stutters....
By ajoesmith in forum Blu-ray RippingReplies: 12Last Post: 12th Oct 2009, 01:31 -
Playing store purchased Blu-ray Movies - The Video and Audio stutters
By orfajackson in forum Newbie / General discussionsReplies: 3Last Post: 10th Oct 2009, 02:28
