    Dec 2013
    California
    I am involved in an Avid editing project where i need to turn all Ustream downloaded FLVs into Mp4s so they can be recognized in Avid AMA bins. I generally use WinFF to do conversion which works great.
    I have one 3hr 45min file that at about 18 minutes in frame size changes from 640x480 to 480x360. I can't get past this point in mp4 conversion. How can i repair and get entire 3hrs 45min into healthy mp4 file? I can see the whole thing play online on Ustream fine.
    Here are the first pass settings in WinFF:
    "C:\Program Files\WinFF\ffmpeg.exe" -y -i "P:\!_AMA-Videos-Tomabo\TimCast_(TimPool)-FLV-download\Timcast January 1, 2012 1 53 AM.flv" -crf 15.0 -vcodec libx264 -acodec libvo_aacenc -r:a 192 -b:a 44.1k -coder 1 -rc_lookahead 60 -threads 0 -r:v 23.976 -b:a 44.1k -ac 2 -vf scale=640:480 "P:\!_AMA-Videos-Tomabo\TimCast_(TimPool)-FLV-download\Timcast January 1, 2012 1 53 AM.mp4"
    Here is FFmpeg command line
    chcp 1252
    title Converting Timcast January 1, 2012 1 53 AM.flv (1/1)
    del "C:\Users\Arthur Klein\AppData\Roaming\Winff\ff131220235833.bat"
    I think both are the same but i am a newbie to WinFFmpeg
    Here is the part of Log that mentions issue before the Convert ends incomplete
    frame=25681 fps=116 q=20.0 size= 379264kB time=00:17:51.29 bitrate=2900.2kbits/
    frame=25745 fps=116 q=20.0 size= 380239kB time=00:17:53.89 bitrate=2900.6kbits/
    frame=25810 fps=116 q=20.0 size= 381158kB time=00:17:56.58 bitrate=2900.3kbits/
    frame=25876 fps=116 q=20.0 size= 381743kB time=00:17:59.37 bitrate=2897.3kbits/
    [h264 @ 000000000c210400] AVC: nal size 21102622
    Last message repeated 1 times
    [flv @ 000000000250bce0] [h264 @ 000000000c210400] Stream discovered after head
    already parsed
    no frame!
    [flv @ 000000000250bce0] New audio stream 0:3 at pos:130670702 and DTS:1081.19s
    Error while decoding stream #0:0: Invalid data found when processing input
    frame=25934 fps=116 q=20.0 size= 382336kB time=00:18:01.13 bitrate=2897.0kbits/
    [flv @ 000000000250bce0] Stream discovered after head already parsed
    [flv @ 000000000250bce0] New video stream 0:4 at pos:130909259 and DTS:1082.19s
    frame=25940 fps=116 q=20.0 size= 382429kB time=00:18:01.13 bitrate=2897.7kbits/
    [h264 @ 000000000c210400] Reinit context to 480x368, pix_fmt: 0
    Input stream #0:0 frame changed from size:640x480 fmt:yuv420p to size:480x360 fm
    t:yuv420p
    Thank you in advance for your help....
    @theGuruWithin
    http://arthurklein.com
  2. afaik ffmpeg can't handle such files (where audio channel count, video resolution, stream formats, or stream ids change)
    -> don't think ffmpeg is the right tool for the job
    vlc might be able to handle such files
    personally I would probably try to split the stream into two parts and process the parts separately
    Dec 2013
    California
    Thank you for your response. I came up with different solution:
    Since file would play online directly from Ustream with no problem.... I decided to you use Open Broadcast Software a community open source screen recorder. I recorded entire 3 hours directly to file (which is one of OBS's options). The resulting file would play in VLC but wouldn't AMA into AVID so i cleansed it with Handbreak using Auto Crop feature which i haven't seen anywhere else. and now the task has been successfully completed and i am able to edit what was the corrupted media.....
