I have a new Nikon CoolPix L820 DSLR which records video as .MOVi have tried 1080p and 720p but the .mov file either does not play or has black screen with audio or film plays but freezes.
i have used VLC, Win media Player, RealPlayer, Quick but all fail. my previous panasonic Lumix filmed as .MOV and all files played OK
the only way i can play the .MOV file is to convert it to .MP4 then play thru VLC, or WMP which is a bit slow. fails on DivX, Quick
my PC is 3GHz 1.2 Gb RAM, Win XP - all software VLC, Win media Player, RealPlayer, Quick is up to date latest version
any help would be greatly received
Results 1 to 9 of 9
yes i mean QuickTime
CompleteName : C:\Camera\Cinderella2.MOV
Format : MPEG-4
Format_Profile : QuickTime
CodecID : qt
FileSize/String : 84.8 MiB
Duration/String : 55s 55ms
OverallBitRate_Mode/String : Variable
OverallBitRate/String : 12.9 Mbps
Encoded_Date : UTC 2012-12-18 17:54:52
Tagged_Date : UTC 2012-12-18 17:54:52
NCDT : NCTG
thx for reply. why does same spec pc play .mp4 but not .mov? -
A few things come to mind. First, I'm not familiar with Nikon, but many phones and cameras (especially older models) don't create files that play properly without being altered first. The early digital cameras shipped with software specifically for converting video files for use in other devices. This would appear to be the case here as well. As you have what "appears" to be a Quicktime "MOV" file, and yet it isn't playable by Quicktime. Second, as noted and depending on the file specs, your PC is likely underpowered. Although this usually results in choppy playback, as opposed to the file not playing at all.
Google is your Friend -
i shot .mov video on 480 res and it played back OK first time with VLC/Quick/DivX/WinMediaPlayer -it didnt hang or just play audio. are the higher spec video 1080 too much to handle?
It would appear that possibly the specs for your computer are not capable of HD playback. Many things come into play when trying to push the hardware into HD playback. Processor and graphics card along with monitor resoltion all play a part. A WinXP machine with only 1.25Gb RAM probably is below the threshold. Check this posting for a quick read on specs for HD playback.http://askville.amazon.com/minimum-PC-specs-needed-play-HDTV-stream-1920x1080@20Mbps/A...estId=42178921
.MOV format problems.
By thanosda in forum EditingReplies: 10Last Post: 27th Dec 2012, 16:17 -
Split/Trim/Join MOV files (works great with Canon SX130's files)
By truchopol in forum EditingReplies: 3Last Post: 27th Jul 2012, 10:35 -
removing background noise in AVI files created from .MOV files
By p_s_92 in forum Newbie / General discussionsReplies: 7Last Post: 23rd Jun 2010, 08:26 -
what is the relation between mp4 files and mov files?
By donaldxdog in forum MacReplies: 3Last Post: 3rd May 2009, 15:28 -
Diference betwen .mov (dv) files and .dv files
By DavidCasillas in forum MacReplies: 9Last Post: 22nd Jan 2009, 21:37
