  1. Hi,
    MediaInfo tells me that the MPEG-dash files from youtube have variable framerate. Is that really correct?
  2. ??
    Why wouldn't it be possible? The mpeg-dash is a container with several video streams(with for example different bitrates).
  4. Hey,
    There is no video standard with the following kind of framerate. Then I thought it could be possible that MediaInfo can't read MPEG-dash files properly, but now I think these files are encoded wrong.
    Video
    Format : AVC
    Format profile : High@L4.0
    Format settings, CABAC : Yes
    Format settings, ReFrames : 3 frames
    Codec ID : avc1
    Duration : 3mn 33s
    Bit rate : 3 105 Kbps
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Variable
    Frame rate : 23.976 fps
    Minimum frame rate : 23.974 fps
    Maximum frame rate : 4 090.909 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.062
    Stream size : 79.2 MiB (100%)
  5. While downloading scanning the incomplete only videostream mp4 file is constant 23,976. I don't get that. Maybe the files are encoded OK?
    I use Lite version 0.7.65
