I've downloaded a DivX movie, the total file size of it is 1,22 Gb; running time is +/- 2 hours.
I want to make a VCD and put it on 2 CD's.
My questions is, does the initial file size determine the final output size?
If so, how can I get it on 2 CD's?
ThanX
The video + audio bitrate and the video length determines the output size but for VCD it is really simple, 1 minute video is 10MB. Remember also that on a VCD or SVCD you can fit near 740 MB on a 74 min CD respectively 800 MB on a 80 min CD because VCD/SVCD is burnt in mode2 form2(less error correction than data cd).
Need Help using AVStoDVD - Output size is HUGE
By Ronny G in forum Authoring (DVD)Replies: 42Last Post: 23rd Dec 2012, 20:27 -
Output size in AVStoDVD
By VenusAndMars in forum Authoring (DVD)Replies: 2Last Post: 25th Nov 2010, 17:07 -
mpeg-2 decoder. What determines which one is used ?
By davexnet in forum Software PlayingReplies: 2Last Post: 22nd Jul 2009, 13:05 -
What determines the speed a CD or DVD is burned?
By bryankendall in forum Newbie / General discussionsReplies: 10Last Post: 30th Mar 2009, 05:08 -
What Determines Your Conversion Speed?
By bangincaraudio in forum Video ConversionReplies: 3Last Post: 15th Nov 2008, 02:13
