Page 7 of 7
FirstFirst ... 5 6 7
Results 181 to 198 of 198
  1. Originally Posted by kimmyk View Post
    Hey there,
    I'm wondering if there's a good way to have an object follow a path like in Flash (at least the old Flash, not sure about now).
    I want to have an image in the background and only mask a portion of it like a mystery sort of thing.
    A path like random zigzag with a round (or anything) see-through mask that moves around the screen showing a portion of the image.
    Is that even possible?
    Thanks Wizzards.
    Not in the way you're probably thinking , or in the way it's done in other programs with splines.
    But if you describe what you want to do more clearly, in terms of what is the "object" and what is the path or pattern over time for the reveal - a possible workaround is the tracking line custom object used as the animated mask.
    You can also use other programs for the animated mask generation, imported into aviutl. For example, you can screen capture YOU drawing out the path in a painting application or image editor (it would be white on black ) and use that as the mask reveal composite in aviutl
  2. Member racer-x's Avatar
    Mar 2003
    3rd Rock from the Sun
    Cool idea PDR...
  3. Everything can be synthesis within Utl:
    1. Add the base image/video
    2. Add a custom object::Line(Motion Track)
    3. Add midpoints to the Line Object
    4. Adjust the path and width of Line object
    5. Copy this Line object to a scene (scene 1 in the attached demo file)
    6. Back to root scene, disable the Line object
    7. Add Mask effect to base image
    8. Select Scene> scene 1 for the mask image
    9. Adjust the mask size (set to 1280 in demo file)
    About the demo file...
    Use 7zip to decompress to somewhere, then use Utl to open the aup file. if you cannot see the base image, just load any image you have instead
    P.S. the GIF preview here seems screwed...
    Stopping development until someone save me from poverty or get me out of Hong Kong...
    Twitter @MaverickTse
  4. Thanks you three.
    I'll have to dig into that, never used the motion trace feature.
    It's for some sort of "searchlight" that shows portions of a product to add mystery, so people have to click a link in the ad to see it all.
  5. Originally Posted by kimmyk View Post
    Thanks you three.
    The principle from my post also applies to search light. Just replace the Line object with a typical circle.
    Add midpoints to the circle object, set X/Y to something other than "No change" and tweak its path
  6. Member racer-x's Avatar
    Mar 2003
    I made this mask in Krita (screen captured), it has lot's of custom brushes and runs in Linux. It makes for a cool effect..
  7. Wow, great!
    (わーい~すっごい!)
  8. Originally Posted by racer-x View Post
    That's pretty cool.
    Another question, I just got this error/from my AVG:
    Win32:Malware-gen
    ....\ivs\Filters\H264DecoderPXT.dll
    C:\AviUtlPack\aviutl.exe
    Is this a false positive, or something else i need to worry about?
  9. [QUOTE=kimmyk;2484055]
    Win32:Malware-gen
    H264DecoderPXT.dll is not part of AviUtl pack so I can't tell.
    aviutl.exe, if you are getting it from VideoHelp or using the installer, it should be fine. FYI, the MD5 for the English UI exe on 64bit Windows should be:
    a0 25 e0 44 53 98 4b b4 3c 39 b4 d6 1d 8e 78 67
    you can verify the MD5 with the command:
    PS C:\AviUtlPack> certutil -hashfile aviutl.exe MD5
    I'd suggest using NOD32, Sophos or Karpersky instead of the free one. Personally I use NOD32 as it rarely give false positive (and quite cheap for the AV-only package). Some AV would complain whenever it encounters a Fast Fourier Transform function... sucks.
  10. Mod Neophyte redwudz's Avatar
    USA
    AviUtl and some plug ins?
  11. could someone here do a video on how to blur subtitles using that Imas Uncaption
  12. Originally Posted by videobruger View Post
    Note that there is a link in that article pointing to my old blog, which is now deleted.
    Parts of my old blog were archived by The WayBackMachine, but don't expect everything was still available.
  13. Last Attempt To Make an English Documentation:
    https://www.kickstarter.com/projects/1093576740/comprehensive-english-documentation-for-aviutl
    Since I took a painful lesson with publishing, this time I will only write with true support gained in advance.
    If this fails, any further request to ask me to write a doc or support for AviUtl will be deem as irresponsible/exploitative and will simply be blocked.
    Jan 2018
    Apatity
    Dear. I would be glad to make a small contribution to this wonderful topic, but at Kickstarter I can not find something like the button "donate". Very much expect you to see the Guide to Aviutl + new releases extrapacks.
  15. Member TeNSoR's Avatar
    Mar 2014
    Hungary, Debrecen
    Hello! Could someone do a video on how to remove a transparent logo in AviUtl? Thanks in advance!
  16. Hi! I need some help with something. I'm working on a 4 minute animation that's basically in HD, right?
    Well, whenever I work on it, the preview for it lags. . a lot. It's so hard for me to work on the animation because of the lag. It makes it hard for me
    to set the timing right for different frames. Is there anything I can do to reduce the lag? Thank you so much in advance!
  17. Originally Posted by emgy805 View Post
    Sadly, not really, except faster hardware
    It's older software, and x86 . So lots of memory issues
    There is a "frames to cache" setting in the system settings you can increase. But it doesn't have advanced cache management or ram previews that other programs have for realtime playback
    Divide and conquer. Don't try to do the 4 minute composition all in project or scene. Break it up into scenes and composite it. It's rare that you would have a 4 minute uncut 1 scene or "continuous take" , even in a pure animation sequence
    You can do some minor things: eg. if your assets are heavy to decode , try to make them easier to decode (e.g. replace with I-frame formats) . If the lag was from decoding many layers, this should help a bit
    But if the "slowness" is from the effects there is not much you can do except to render out some elements and bring them back in, so it doesn't have to render the effects on the fly
