Results 1 to 14 of 14
  1. Member blinky88's Avatar
    Mar 2004
    Australia
    I have been searching for hours and have not been able to come up with a solution, help would really be appreciated.
    Cheers from downunder.
    Feb 2004
    Australia
  3. What is wrong with ffmpeg? https://trac.ffmpeg.org/wiki/Encoding%20VBR%20%28Variable%20Bit%20Rate%29%20mp3%20audio
    ffmpeg -i %1 -codec:a libmp3lame -q:a 2 -ac 2 %1.mp3
  4. MeGUI's audio converter will also do it.
    Mar 2011
    Nova Scotia, Canada
  6. Member PuzZLeR's Avatar
    Oct 2006
    Toronto Canada
    I too say MeGUI (and LAME) is simple enough.
    I hate VHS. I always did.
  7. Originally Posted by PuzZLeR View Post
    Nothing is simpler than ffmpeg and one comand line... two programs are not simpler than one.
  8. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    That is kind of like saying using EAC with lame or flac is more complicated because you are using 3 programs......
    When one is just the frontend and uses lame or flac to encode.
    You can use one program on the front that uses more than one other program or software but that does not make
    more complicated or less "simpler" to use.
  9. Member PuzZLeR's Avatar
    Oct 2006
    Toronto Canada
    The expression "simple enough" is not synonymous with "simpler".
    Regardless, I agree with you in the point of view of computational complexity, but if I can avoid having to write any command line by using a front end (via the second program) I find that simpler in terms of a point-click-keystroke logistical sequence.
    Besides, aren't front ends, or GUIs, for CLI-based programs designed to make your life simpler?
  10. Originally Posted by Noahtuck View Post
    Example not fair as EAC is ripper with encode functionality - where conversion between formats is not EAC task.
    As i understand idea behind example then i don't understand why use two programs instead one where this program provide probably highest possible quality (SoX resampler if required, all LAME options, decent AC3 decoder) in one binary.
    But OK as principle - i was quite curious why bother with possible problems related to pipe, formats to exchange data etc. but OK and it is up to topic author.
    Fair point and my mistake - simpler doesn't mean simplest, simple enough is not simpler - blame me not being native English.
    AFAIR there is at least few GUI's for FFMPEG - bot sure how they follow ffmpeg changes but IMHO copy + paste in notepad is not so difficult task especially that this batch can be used in GUI also.
  11. Member PuzZLeR's Avatar
    Oct 2006
    Toronto Canada
    Yes, a Notepad template, and cut and paste, makes much of the pain go away when using CLI based programs, especially when you use the program repetitively. I do this with AviSynth too (and sometimes Notepad feels like a frontend/GUI).
  12. Originally Posted by PuzZLeR View Post
    My point was that you can "drag & drop" on batch - thus not problem at all with semi GUI ffmpeg... from very simple script to very fancy - more or less similar functionality - funniest thing is that some people building in some xxxxbuilder GUI wrapper over ffmpeg and they want to have money or worse (adware/spyware/trojanware etc).
    http://ffmpeg.zeranoe.com/forum/viewtopic.php?f=17&t=957
    https://anaheimofmanheim.wordpress.com/2012/12/31/drag-and-drop-multiple-files-for-bat...eg-processing/
    http://pcloadletter.co.uk/2011/06/15/batch-ffmpeg-transcoding-script/
