  1. friend i have a movie in two different language 1st is 2 hour 40 min (720p) and 2nd 3 hour 2 min (1080p) i want to replace 720p video with 1080p but sound from 720p video. so i need to to trim some 1080p video.. so the length of 1080p will 2 hour 40 min and audio fit on that video....
    pleease help which software i use or what i do to make this possible
    i need any ssoftware that show me both video at the same tim so it will help me to choos the correct trim or like this software
    i already extract audio and video.. from both files...
    Video
    Format : AVC
    Format profile : High@L4.1
    Format settings, CABAC : Yes
    Format settings, ReFrames : 3 frames
    Muxing mode : Header stripping
    Codec ID : V_MPEG4/ISO/AVC
    Duration : 3h 8mn
    Bit rate mode : Variable
    Bit rate : 6 076 Kbps
    Maximum bit rate : 40.0 Mbps
    Width : 1 920 pixels
    Height : 816 pixels
    Display aspect ratio : 2.35:1
    Frame rate mode : Constant
    Frame rate : 24.000 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.162
    Stream size : 7.85 GiB (98%)
    Writing library : x264 core 115 r1995 c1e60b9
    General
    Format : AVI
    File size : 695 MiB
    Duration : 2h 40mn
    Overall bit rate : 604 Kbps
    Writing application : VirtualDubMod 1.5.10.2 (build 2540/release)
    Writing library : VirtualDubMod build 2540/release
    Video
    Format : MPEG-4 Visual
    Format profile : Advanced Simple@L5
    Format settings, BVOP : 1
    Format settings, QPel : No
    Format settings, GMC : No warppoints
    Format settings, Matrix : Custom
    Codec ID : XVID
    Codec ID/Hint : XviD
    Duration : 2h 40mn
    Bit rate : 515 Kbps
    Width : 608 pixels
    Height : 256 pixels
    Display aspect ratio : 2.40:1
    Frame rate : 24.975 fps
    Color space : YUV
    Bit depth : 8 bits
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 0.132
    Stream size : 592 MiB (85%)
    Writing library : XviD 1.2.1 (UTC 2008-12-04)
    Audio
    Format : MPEG Audio
    Format version : Version 1
    Format profile : Layer 3
    Mode : Joint stereo
    Mode extension : MS Stereo
    Codec ID : 55
    Codec ID/Hint : MP3
    Duration : 2h 40mn
    Bit rate mode : Constant
    Bit rate : 80.0 Kbps
    Channel count : 2 channels
    Sampling rate : 32.0 KHz
    Stream size : 92.1 MiB (13%)
    Alignment : Aligned on interleaves
    Interleave, duration : 40 ms (1.00 video frame)
    Interleave, preload duration : 504 ms
    Writing library : LAME3.98r
    Encoding settings : -m j -V 4 -q 2 -lowpass 13.5 -b 80
  2. Originally Posted by abhaybad View Post
    You haven't provided nearly enough information. For example, one could be from a PAL source and the other from NTSC. Nor have you given us the video and audio formats, MPEG-2 video, XviD, x264, what?
    Please post the MediaInfo information about them both. Open them one at a time, go View->Text, and post the information for each. And there may not be such a program as you want.
  3. Originally Posted by manono View Post
    ok... updated...
  4. Banned
    New York, US
    What do you want for final output? BluRay disc? AVCHD? A PC-only final format? How do you want to play the final output?
    Neither of the videos is 1080p, and neither is 720p. The long video is encoded at 1920x816 @ 24FPS. The other is encoded at 608x256 at 24.975FPS (a different frame rate from video #1) and has mp3 audio at a sampling rate of 32KHz; neither mp3 nor 32Khz is valid for standard BluRay or AVCHD. So you'll need more than just an "editor". Aside from the different video and audio frame rates, one would assume that you want PC-only playback for the final video (?).
  5. Originally Posted by sanlyn View Post
    The 1920x816 one was once 1080p, before being cropped and reencoded. The other one was most likely from an NTSC DVD and 480i before being unblended and reencoded to XviD. Both were downloaded I would think.
    The first step is to convert both audios to WAV audio at the same 24fps 'framerate' and the same sample rate (48.0 KHz). From there, good luck. It's a difficult project considering you have two different cuts of the same film.
    What's wrong with the audio from the 3 hour 8 minute version? Wrong language? You could always buy the Blu-Ray in your language. The audio from the XviD is garbage quality anyway. Believe me, if your time is worth anything at all it'll be way easier and cheaper in the long run to buy the film version you want, considering you had to ask how to accomplish this.
