  1. hey everyone,
    i recently started ripping dvd's.....
    every time i get done with the finally encode, it's always way out of sync, and if i sync the total audio, it goes out of sync at a later place. i'm using gladdvd xp (ripping the whole dvd, don't know about other options), then using dvd2avi for frameserving (with force film off) and then tmpegenc to encode.... i tried using the source range..... i just set the start frame when the audio actual starts (with the picture) and ending the same...... it's getting all out of sync...and i just have no clue what to do... if anyone could help me, i'd apreciate it......
    thanks
  2. Try disabling your screensaver setting, set your power scheme to ALWAYS ON, system standby to NEVER, turn of monitor to NEVER, and turn off harddisks to NEVER.
    You can change these by going to control panel -> display -> screensaver.
  3. latest version of dvd2avi giving ppl audio sync probs...try using older versions
