Do you know any dvd creator that support flv( flash video file) file?
What kind of dvd creator are you looking for then? Create complex menus? DVDStyler or Tmpgenc authoring works might work.
That's exactly what it is. From Baldrick's beginner's guide for its use:
With the free AVSTODVD you can convert most of your video files to standard DVD-Video that will work on most standalone DVD Players.
AVSTODVD supports most formats like avi, mp4, mkv, flv. -
Avstodvd does that.
If it fails can you try convertxtodvd or the free freemake video converter.
How to join four .flv files in to one .flv file using ffmpeg?
By spiderMan007 in forum EditingReplies: 3Last Post: 26th Aug 2012, 13:18 -
Authoring DVD's with .flv files
By kasfig in forum Newbie / General discussionsReplies: 2Last Post: 15th Mar 2012, 11:05 -
Any DVD players that play FLV files?
By wulf109 in forum DVD & Blu-ray PlayersReplies: 3Last Post: 8th Apr 2011, 13:02 -
DVD creator that support MTS video files
By 1234567 in forum Authoring (DVD)Replies: 3Last Post: 19th Jan 2010, 20:07 -
Multiple FLV files into 1 big FLV file, how??
By vividbreeze in forum Newbie / General discussionsReplies: 1Last Post: 16th Dec 2008, 15:11
