Hi All.
My first attempt at ripping, I'm ripping Futurama, Volume 1 using SmartRipper.
I'm following Sefys guide on how to do this, yet when I rip, it only rips one episode of the DVD at a time, depending on what I have selected under "Source, Input, Title Input, Program Chain, Angle *".
Is there any way of making SmartRipper select them all, so I can just have one rip rather than five or am I doing something wrong here?
Any help much appreciated.
cheers
Dave
Yeah, just change the rip method in SmartRipper from Movie to Files or even Backup. That will allow you to select as much as you want from the DVD. Backup copies everything on the DVD, which may be more than you need. Files allows you to choose what you want to rip.
gonz0's idea is not a good one...unless u plan to use flaskmpeg/avisynth to framserve to tmpgenc...
this is because file/backup mode doesn't remove multi-angles, if the dvds you're ripping has them, you will have problems, unless u use flaskmpeg (it will allow you to choose which angle you want)
otherwise, you should use movie mode because it gets rid of any multi-angles, ripping the episodes separately shouldn't be too much of a hassle
Wrong m2v file length with SmartRipper
By kenj in forum DVD RippingReplies: 9Last Post: 11th Jul 2010, 19:44 -
PAL/NTSC DVD/VCR combo that will play DVD+R's w/o A/V synch problems?
By wetcamelfood in forum DVD & Blu-ray PlayersReplies: 12Last Post: 12th Jan 2010, 17:25 -
AutoGK, DVDShrink, SmartRipper won't recognize stream language/info
By takearushfan in forum AudioReplies: 5Last Post: 26th Sep 2009, 21:21 -
SmartRipper -- question about "Search Intensity" setting
By Dr.Rock in forum DVD RippingReplies: 1Last Post: 30th Dec 2008, 15:26 -
DVD Editing from Panasonic VDR-D220 Mini DVD and interlacing problems
By gbnz in forum EditingReplies: 3Last Post: 15th Oct 2008, 15:34
