i was thinking about the movie, Meatballs, when i it occured to me to go on imdb. i always use google search as my doorway to these sites. when i looked down in the googles searches i saw they made up to 4 sequels. they made Meatballs 4, didn't even know. i'm sure its nothing like the first.
so i was thinking, there must be a feature or place to find out how many sequels were made for any movie. i went on imdb first, but didn't see anything like "sequels made" or something like that.
is there any official place to go and find this ? or do you have to google it like it did. it sure would make life much easier if all i had to do is type in a movie that i'm curious about and it tells me there are sequels and the names. thank you.
On IMDb there is a movie connection selection. Just use the quicklinks bar to find it. I hope that helps.
that did it, thank you!
also, if you are on google search, you will get a drop-down listing of similar as you type in the following...
(i didn't know this because i was on my netbook and i don't have that feature turned on i guess)
Code:imdb meatballs connection
I cant get the same quality as the original
By hrgwea in forum Video ConversionReplies: 3Last Post: 3rd Nov 2013, 18:00 -
original DVD subtitles Help
By cavusozkan in forum Authoring (DVD)Replies: 5Last Post: 29th May 2010, 16:18 -
Editing original menu.?
By cavusozkan in forum Authoring (DVD)Replies: 4Last Post: 16th May 2010, 14:18 -
Using original menu
By gouletjo in forum Authoring (DVD)Replies: 5Last Post: 16th Feb 2010, 20:06 -
How to add Subtitles to original DVD whitout loosing original subtitles ?
By Chainsaw_1 in forum Newbie / General discussionsReplies: 2Last Post: 6th Jan 2010, 13:52
