Hi All,
I have about 200 mp4's which I wish to convert to save disc space. When these are converted, I want the new file to reside in the original source folder. I don't want to have to move them all around or specify output folders for every file.
Anyone know of any software to do this?
To anything which reduces the file size and can be played on a PC without any specialist software being installed. It needs to be transferred and played on a number of machines which will have restrictions placed on them for installing software.
Most all-in-one converters has batch feature and you don't have to specify output for every file. Like xmedia recode, vidcoder, freemake video converter, video to video converter. But I don't think anyone can keep same folder as source if you are loading from several different folders.
But it's harder to pick format. AVI with divx/xvid might require a codec on older machines. WMV(wmv3) should work on most windows systems without installing anything. MP4(h264) will work on most newer windows system(wmp 12 and later).Last edited by Baldrick; 6th Dec 2013 at 05:09.
Baldrick, thanks for your informative response. I'll take a look at the programs you have suggested and give them a go.
Recusion is easy with a batch file and a command line encoder. Here's an example that converts all M4A files to WAV files:
Automatically determining what bitrate to use will require a bit more work.Code:dir/b/s *.m4a >m4alist.txt for /F "delims=;" %%F in (m4alist.txt) do "g:\program files\ffmpeg\bin\ffmpeg.exe" -i "%%F" -f wav -ac 2 "%%~dF%%~pF%%~nF.wav" del m4alist.txt
DOS: redirect the output of an executable into a batch variable?
By RogerTango in forum ProgrammingReplies: 2Last Post: 7th May 2012, 09:36 -
Batch FLV to F4V - Keep File Structure of Source
By iSerce in forum Video ConversionReplies: 3Last Post: 23rd Jun 2011, 06:20 -
Handbrake: Output picture size after conversion differs to source
By RF264 in forum DVD RippingReplies: 5Last Post: 11th Mar 2011, 08:02 -
v2mp command line not changing output file location
By Wakewatcher in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 18th Jan 2011, 14:20 -
Delete Source Files after batch process has ended
By Metallo in forum Video ConversionReplies: 3Last Post: 24th Mar 2010, 19:10
