God I need help. I tried ripping Dvd's to hard drive, used tmpeg to convert them to pal vcd, using the template. Then I changed the Audio to the correct specs (48000 224). Load the files into spruceup and made the menu's. Saved it out to burn with nero. I checked the vob files with a player and they were out of sync very bad. The video frame rate was jumping from .40 to 116. When I take a bought vcd and do the same it works great.....
So I'm doing something wrong, and I have no idea what. If someone else does this on pal systems and ntsc and have templates that work 100% that I can use, can they email them to me.
I can see most of you know what you are doing, can someone make a old man happy and put me right!
Thanx in advance
Bob
what was the solution?
plus how did you manage to convert 44KHz to 48KHz, when i try i get a track with no audio :(
Vcd audio problems
By Ak_wf1 in forum AudioReplies: 5Last Post: 26th Nov 2011, 21:19 -
Vcd audio problems
By Ak_wf1 in forum Authoring (VCD/SVCD)Replies: 1Last Post: 26th Nov 2011, 20:59 -
Problems with DVD to VCD, including no audio. Help!
By gastrof in forum Newbie / General discussionsReplies: 8Last Post: 4th Jan 2008, 13:39 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 07:54 -
Follow up : audio problems with VCD authoring
By thelotusman in forum Authoring (VCD/SVCD)Replies: 5Last Post: 9th Jun 2007, 19:34
