So I have some mkv files(anime), they are choppy and I want to smoothen them like TV's now do
BUT i dont want them to be in real time, i want to create new files which would have the extra frames
Thanks in advance
Results 1 to 12 of 12
Got a sample?
Know any AviSynth?
http://forum.doom9.org/showthread.php?t=160226 -
Try this:http://www.spirton.com/convert-videos-to-60fps/ Works real good.
What kind of filters?
Here's an example of doubling frame rate with AviSynth an MvTools:
https://forum.videohelp.com/threads/350929-Progressive-to-Interlaced-covertion-adding-c...=1#post2200764
And arbitrary frame rates:
https://forum.videohelp.com/threads/352741-Frame-interpolation?p=2215188&viewfull=1#post2215188 -
Their workflow that is posted on that site http://www.spirton.com/convert-videos-to-60fps/ is using MeGui , that is setting up Avisynth script , but there is a part that you have to copy/paste some lines in it anyway, so you just copy/paste your filters there also.
when i try to open the video it says:No combination of filters could be found to render the stream
and if i try to install K Lite codec pack it says that it will remove my current filters/codecs -
Just install it. Of course it's going to remove the old install. That's just good housekeeping, and for safety against virii.
Here's an example but with speed changes:
https://www.youtube.com/watch?v=aNgJeCycScU
Smooth frame by frame accelerated video playback?
By Malachaidc in forum Newbie / General discussionsReplies: 10Last Post: 30th Jul 2012, 12:40 -
Please can someone help with frame-by-frame video editing?
By likasombodee in forum EditingReplies: 2Last Post: 6th Mar 2011, 20:06 -
Looking for software to view frame by frame video
By MePool in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 13th Jan 2011, 17:39 -
extracting jpeg frame by frame from video
By goofymickey in forum ProgrammingReplies: 0Last Post: 16th Dec 2010, 08:02 -
Best software for Frame by Frame Video Edit?
By VEBouto in forum Newbie / General discussionsReplies: 5Last Post: 8th Feb 2010, 17:28
