I'm using a avermedia PCI-e capture card and after a lot of searching for how to use virtual dub, I've almost got everything set up right. Only problem is now I can't have audio unless I want to play at 5 fps. I select audio playback to get audio and then select the second line for audio source (audio is pretty stuttery most of the time) which is how I currently get audio, however it is set to no source now, that way I can actualyl play at normal fps.
What am I missing? I want audio and high fps. Thanks for any help you can give!
Do yourself a favor and post your system specs ... this goes a long way to solve such issues.
Virtualdub is not a player and has issues when used for that purpose ... it can capture, filter, edit. save, frameserve, and other things but as a player forget it ... you will have problems.
PS : Welcome to the forums
Virtual Dub 1.9.11- Capture audio sections and use them in the same video
By vjmehra in forum Video Streaming DownloadingReplies: 2Last Post: 24th Oct 2013, 15:44 -
Virtual Dub say's No audio decompressor to decompress source audio
By s_joy09 in forum Newbie / General discussionsReplies: 10Last Post: 25th Dec 2011, 15:03 -
problem with compression using virtual dub
By jpez1 in forum Video ConversionReplies: 4Last Post: 3rd Aug 2010, 14:24 -
no options in audio compression for virtual dub
By jonbaker in forum AudioReplies: 9Last Post: 14th Feb 2010, 20:00 -
Virtual Dub problem
By rocka in forum EditingReplies: 3Last Post: 2nd Jan 2009, 04:46
