This does not work.
ffmpeg -i MVI_3298.MOV -y -filter:v "crop=600:720:270:0" -ss 00:01:14 -t 00:00:09 -acodec copy -vcodec copy ay.mov
This works.
ffmpeg -i MVI_3298.MOV -filter:v "crop=600:720:270:0" -ss 00:01:15 -t 00:00:06 -an -vcodec h264 ay.mov
I want to crop the video without transcoding.
Code:ffmpeg -version ffmpeg version 2.0.1 built on Sep 24 2013 05:31:18 with gcc 4.8 (Debian 4.8.1-10) configuration: --extra-cflags=-I../static/include --extra-ldflags='-L../static/lib -static' --enable-gpl --enable-version3 --enable-static --disable-shared --disable-debug --enable-runtime-cpudetect --enable-libmp3lame --enable-libx264 --enable-libspeex --enable-libvorbis --enable-libvpx --enable-libfreetype --enable-libxvid --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libtheora --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-gray --enable-libopenjpeg --disable-ffserver libavutil 52. 38.100 / 52. 38.100 libavcodec 55. 18.102 / 55. 18.102 libavformat 55. 12.100 / 55. 12.100 libavdevice 55. 3.100 / 55. 3.100 libavfilter 3. 79.101 / 3. 79.101 libswscale 2. 3.100 / 2. 3.100 libswresample 0. 17.102 / 0. 17.102 libpostproc 52. 3.100 / 52. 3.100
Video File Info
Code:Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'MVI_3298.MOV': Metadata: major_brand : qt minor_version : 537331968 compatible_brands: qt CAEP creation_time : 2013-11-30 02:00:02 Duration: 00:01:33.79, start: 0.000000, bitrate: 24748 kb/s Stream #0:0(eng): Video: h264 (Constrained Baseline) (avc1 / 0x31637661), yuvj420p, 1280x720, 23203 kb/s, 29.97 fps, 29.97 tbr, 30k tbn, 60k tbc Metadata: creation_time : 2013-11-30 02:00:02 Stream #0:1(eng): Audio: pcm_s16le (sowt / 0x74776F73), 48000 Hz, stereo, s16, 1536 kb/s Metadata: creation_time : 2013-11-30 02:00:02
FFMPEG command to arguments
By wolfox in forum ProgrammingReplies: 4Last Post: 22nd Oct 2012, 02:33 -
ffmpeg: is it possible to crop while cropping rect tracks a fixed point?
By feelart in forum EditingReplies: 5Last Post: 18th May 2012, 04:09 -
Program for cropping a video as one would crop an image
By mgmt in forum EditingReplies: 4Last Post: 28th Mar 2012, 05:08 -
ffmpeg command lines not working.
By PsyDonias in forum Video ConversionReplies: 23Last Post: 5th Dec 2011, 09:04 -
FFMPeg CLI : How to crop and pad?
By Bonie81 in forum Newbie / General discussionsReplies: 6Last Post: 26th Jun 2011, 07:31
