  1. I have a big issue with the batteries (normal kind) they disharge very fast in like 2 weeks !
    The strange thing is that they're still half charged (5.4 on a 9V scale with the bat. tester).The remote transmit nothing with that voltage, it's a fact.
    I use this remote to control my pc
    Could it be the belkin bluetooth adapter i use's fault or smtg else i really wonder at this point.
    Help is welcome
    Oct 2005
    666th portal
    why not use the usb cable? bluetooth is a power hog.
  3. you're off topic, there is no way to use a usb cable to charge the bd remote
    http://www.remotecentral.com/ps3_bd/photo07.htm
    i have the model on the right
  4. Member yoda313's Avatar
    Jun 2004
    The Animus
    Maybe the remote is going bad?
    I'd check online. I'm sure you can get a cheap replacement.
