hey there, Ive been getting an error while trying to copy a DAT file from original VCDs into my computer. I get a "INVALID MSDOS FONCTION" error message.
I've seen those movies on a VCD player, but I can't play them nor copy them on my PC
Does anyone knows what's it about ?
I encountered a similar problem before. We couldn't read a movie file from a VCD when we used Windows NT. However, when we used Windows 98 on the same PC (it was dual-boot), we were able to read the movie file. Our guess is that the CD-ROM drivers for NT are not as good as those for Win 98. A suggestion would be to look up updated drivers for your CD-ROM drive.
Hope this helps.
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
It works now, the cd was scrached a bit I think that's what caused it
thx 4 the trouble
Convert AND Combine Multiple VCD DAT files to Single Divx/Xvid file
By GrayStrickland in forum Video ConversionReplies: 4Last Post: 17th Aug 2012, 13:23 -
VCD dat files
By mayflower in forum Newbie / General discussionsReplies: 1Last Post: 18th Mar 2009, 07:50 -
Extracting jpg photos from the ITEM####.dat files in the VCD segment folder
By H-Man1953 in forum Newbie / General discussionsReplies: 5Last Post: 15th Aug 2007, 07:54 -
How to create dat files?
By dimtim in forum ComputerReplies: 8Last Post: 6th Aug 2007, 08:03
