right now my video has a unusual framerate and I want to convert it into 29.97 proper.
I tried the virtual dub way, but the conversion was wrong and I couldn't merge this video segment with proper 29.97 videos.
h264 avi with mp3 audio, how do I convert this improper 29.97 to actual 29.97 frame rate? thx
Results 1 to 10 of 10
AnonymousGuest
AnonymousGuest
say I use virtualdub to change the frame to 29.97, this is just the actual NTSC standard fraction taken to the 2 decimals, but the fraction keeps going, and my approximation ignores the rest of the fraction.
I need to convert this frame to the actual NTSC standard framerate, but I can't do it with virtualdub -
AnonymousGuest
what specific information are you looking for?
he asked what I meant by improper, and I told him what I thought the answer was. are we on the same page here? -
Possibly you're using variable frame rate (which is evil)?
And BTW, judging from the near total incoherence of your questions I'd suggest you use something else that virtualdub. Perhaps handbrake or vidcoder or avidemux. -
Use AviFrate on the AVI you created with VirtualDub. Change the numerator to 30000 and the denominator to 1001.
But most programs ignore the difference between 29.97 and 30000/1001. The most notable exception is VirtualDub -- which will not let you append a video with slightly different frame rate.Last edited by jagabo; 1st Dec 2013 at 11:00.
AnonymousGuest
so it really is just a simple header change? damn, I thought frame rate data actually affect the way the video is stored
In an AVI file the frame rate does effect the interleaving of audio and video chunks. But that doesn't matter much for editing purposes. And, of course, if you change the frame rate by a significant amount you will get audio sync problems. Otherwise, the frame rate is just a pair of numbers in the header.
how to change frame rate of n aoudio tracK?
By hunter111 in forum AudioReplies: 5Last Post: 26th Aug 2013, 06:49 -
How to change Frame rate?????
By Choey in forum Video ConversionReplies: 9Last Post: 29th Jun 2013, 02:23 -
Change frame rate?
By cincilator in forum EditingReplies: 6Last Post: 15th Oct 2012, 14:45 -
how to change frame rate on staxrip?
By VistaXP in forum Video ConversionReplies: 6Last Post: 6th Apr 2011, 15:13 -
Help with understanding when to change frame rate
By mlaran in forum Video ConversionReplies: 3Last Post: 22nd Feb 2010, 11:11
