    Nov 2013
    Canada
    Unable to switch to capture mode.
    I have seen so many people having this problem. Is there a solution to it?
    When I installed the Video Studio Ultimate capture function worked.
    Not sure what or which update caused capture not to function.
    SD capture works, HD capture does not. Can anyone help.
    I tried to install new driver, go back to old one. I tried restore.
    I had this problem with studio 4 in the past, then it started to work again.
    But now neither can capture. I instaled trial versions of Director 12 and Premier CS 6
    Capture works on both. This a shame that Corel does not fix this problem
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Any bets on another first-time-poster showing up with a miracle solution....also full of buzz-words?
    Nov 2013
    Canada
    Not sure what to expect from this forum. Thanks for the answer anyway. Yes I have seen many suggestions. I guess I have invest another $100.00.thanks, if anyone knows something, please let me know.
