Hi Guys,
I've read as much as I could find on MKVMerge command line, but I'm really struggling as a newb...
My goal is to convert a large number of Itunes (DRM Free) M4V files to MKV files, maintaining the same audio/video contents.
I've seen this command thrown around, and I imagine I could simply edit is, as I did below... However, I'm not sure how to use it:
FOR %I IN (*.avi) DO mkvmerge -o %I.mkv %I
to
FOR %I IN (*.m4v) DO mkvmerge -o %I.mkv %I
Do I simply put it in a batch file, in the same directory as the videos?
Do I put it in the MKVToolNix directory?
Do I need to include the program/input/output paths?
Nothing I've tried seems to work.
Any help would be really appreciated!
The file names have spaces in them, if it matters...
Check my ffmpeg batch tutorial. Instead of ffmpeg use mkvmerge, https://www.videohelp.com/guides/how-to-batch-convert-multiplex-with-ffmpeg-id1272#1272
edit: Or you can also try use ffmpeg instead of mkvmerge...just use -vcodec copy -acodec copy -
I delved into this question and came up with this answer. It involves using a quickbasic compiler called QB64 (google it)
to create batch files. You can modify it to your preferred content. Not complicated. Please download the QB64 GL version it's
self contained, does not require the .dll's to be included in the execution directory. It's found in the forum on QB64 site.
The chapters file will give 4 minute spread hard chapters (99 of them). Very playable with VLC. Or don't use it. The
downside to the chapters.txt file you have 99 chapters for 6 hours 32 minutes. Even if your video is only 32 minutes long.
It works (ugly), but it works.
The main good part about this process. The original files are not touched. MKVMERGE copies the file into a new container.
IMPORTANT: Must be in different directories (input) (output). Or your mileage will not vary
The qb64 program: Called "mkvchaps" attached as RAR
Chapters file: Called "chapters" attached as RAR.
What needs to be in the execution directory: I call it MP4BOXCHAPS
CHAPTERS.TXT
js32.dll
libeay32.dll
libgpac.dll
MediaInfo.dll
mkvchaps.exe
mkvmerge.exe
MP4Box.exe
msvcr100.dll
ssleay32.dll
Some of these programs and dll's can be found in MP4BOX gui and MKVTOOL's. You only need to compile the
QB64 program with your options and directories. And include it in the directory. All attachments are text files
no EXE's are present (virus safe).
The chapters.txt file can be modified to different minute spans. It's only text.
Ron
Script to Batch edit MKV files with MKVMerge or any other program
By Animebuster in forum EditingReplies: 3Last Post: 21st Oct 2013, 19:17 -
Batch subtitle muxing - mkvmerge
By mkr10001 in forum EditingReplies: 1Last Post: 18th Feb 2012, 13:03 -
dtshd / mkv to m4v
By roughsporty in forum AudioReplies: 1Last Post: 13th Dec 2011, 14:57 -
Coding Help to go from MKV to M4V
By zombiefreak in forum Video ConversionReplies: 0Last Post: 9th Oct 2011, 22:19 -
MKVMerge Batch Command Help
By DarrellS in forum Video ConversionReplies: 1Last Post: 31st Oct 2010, 17:05
