Hello.
For a while I've been looking into ways to effectively extend the optical zoom range of my Panasonic camcorders (HC-V520 & HC-V720), but alas to no avail. I tried a number of the lower price range conversion lenses, such as Sony VCLR 2x & 4x telephoto lenses. But it only seems to work up to about half of the camera's zooming range; past that, the chromatic aberration at full zoom gets so bad, that the equivalent digital zoom looks better than the supposed "optical" image you're getting with these lenses (for example, at a 50 x optical with a 2x lens attached, a 100x digital zoom actually looks much better than the 100x optical you should be getting). Up to about 50% of the optical zooming range (25x for HC-V520 & 12x for HC-V720) the attached lens works fine, but after that, the chromatic aberration increases significantly (so that basically in practice, you get no increase in usable optical zoom whatsoever). Is there actually a kind of univeral telephoto lens with high quality optics that would fit my cameras, and at the same time provide a real increase in optical zooming power without image distortion, at all zooming levels?
Results 1 to 1 of 1
Panasonic NV-GS50 lens gone?
By CrazyBugga in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 6th Oct 2016, 10:41 -
Canon Camcorders Picture Quality
By silegnav in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 20th Sep 2013, 10:22 -
Sony PMW-EX 1 + Telephoto Converter Lens
By B-Twien Bytes in forum Newbie / General discussionsReplies: 0Last Post: 29th Jun 2011, 08:27 -
Panasonic VW-CLT1 3D Converter Lens
By nwo in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 13th May 2011, 11:14 -
Creating m2ts video and file structure for camcorders and panasonic g10 tvs
By pkitten in forum Video ConversionReplies: 6Last Post: 29th May 2009, 09:21
