Please help!! I am trying to make a MPEG2 file with LSX-MPEG Encoder 3.5 in MPEG 2 SVCD NTSC profile, but getting an error message
"Encoder failed to decompress AVI video stream. Possible reason: Can not find appropreate video codec. AVI file may be corrupted or use unsupported video compression format. Please select valid input AVI file"
The avi file has been edited in Adobe Premiere 6 and has been captured with digital mini DV camcorder.Thanks in advance
Sounds to me that you have to decompress it first !
in Virtual Dub, Version 1_4_8 or 1_4_9.
1. Go to File (Open video file) load your Avi file.
2.Go to Video. (Mark, Direct Stream Copy)
3Go to Audio. (Mark, Full Processing Mode)
4.Go back to File (Save as Avi) rename the file or it will erase the original file, hope this works out for ya ........ :D -
Thanks for your reply. I have downloaded the Virtual Dub 1.4.9. version and tried to open video file there. Unfortunately got an error message
"Couldn't locate decompressor for format 'dvsd' (unknown).Virtual Dub requires a video for Windows (VFW) compatible codec to decompress video. DirectShow codecs, such as those used by Windows Media Player, are not suitable."
I have found and downloaded the DV AVI(dvsd) Import plugin for Adobe Premiere from the site http://www.kazemachi.ne.jp/dv/imdvsd.html but Iit didn't help or at list I couldn't make that plug in work for me. Any suggestions, please.
Avi to dvd conversion problem
By Psco2007 in forum Authoring (DVD)Replies: 5Last Post: 28th Feb 2011, 12:34 -
AVI to MPG Conversion Audio Problem - please help!
By Nuzy in forum Video ConversionReplies: 4Last Post: 17th Nov 2010, 22:34 -
problem with conversion from DV-AVI to DVD
By obadvw in forum Video ConversionReplies: 1Last Post: 24th Jun 2009, 17:08 -
MPEG-2 528x576 to AVI conversion problem.
By madman1987 in forum Video ConversionReplies: 7Last Post: 3rd Feb 2009, 10:53 -
Joined avi file conversion problem
By siberian50 in forum MacReplies: 12Last Post: 26th May 2007, 19:04
