Ok, I have a strange problem. Was trying to put films from my Canon HFR16 to a DVD, creating menus using MultiAVCHD. Eventually it worked, I also played with AVCHDCoder.
Tested it with noname DVD+RW, LG BD650 player see it as AVCHD and it worked fine.
Burned it to a Lightscribe TDK DVD+R. Doesn't work, player LG BD650 ejects it moments after stating it is an AVCHD disk.
Burn it to JVC DVD+R setting booktype to DVD+RW. Works great.
Burned it to Lightscribe TDK DVD+R setting booktype to DVD+RW. Failure again.
Burned it to Verbatim DVD-R, no booktype setting, works great.
All burns test fine in CD-Speed, I've used the lightscribe disks without any problems before (burning regular DVD films)- the children like disks with pictures and can't use the originals obviously.
While I agree that Verbatim, and especially JVC, are better quality than TDK, in this case I can't believe it's the burn quality. If anything, my well-used noname DVD+RW would be the weak link in this case.
Is there any way my DVD/BD-player could see the lightscribe disk in a different way than a "normal" DVD and refuse it for whatever reason?
I'm reluctant to import a bunch of lightscribe disks if they continue to fail for family films using AVCHD. I'm moving away from DVDs anyway, these disks are for family and relatives - I burn my AVCHD on BD-R for myself. (Lightscribe disks are rare in my country, and expensive).
the real manufacturer of the lightscribe disc is most likely cmc. they aren't good. stick with decent verbatim or taiyo yuden. if you are going to bitset dvd+r it should be to dvd-rom not dvd+rw.
Result doesn't match my AVCHD quality
By davidplante in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 22nd Mar 2012, 09:37 -
AVCHD on hard drive: creating new AVCHD folder structure
By Phil_W in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 1st May 2011, 14:46 -
Will AVCHD-DVDR work on DL DVD?
By cheerful in forum Authoring (Blu-ray)Replies: 8Last Post: 14th Aug 2010, 22:54 -
software to batch convert m2ts format avchd to mts avchd?
By masterpug in forum Video ConversionReplies: 0Last Post: 14th Aug 2010, 01:06 -
Best AVCHD codec that will work with Vegas?
By The111 in forum Newbie / General discussionsReplies: 9Last Post: 2nd Nov 2009, 21:54
