hi , i have a problem with my recordings, i get a horrible noise , what it can be? where come from?
i attach one example .
thanks![]()
Results 1 to 11 of 11
you right, i use vlc and pot player, but both give me some kind of background noise, you dont ear it?
but i test on my tv and it sounds fine.
its weird, because i have 2 capture cards, one 2250 and one 1600 hauppauge, 2250 give me this sound,
for rencode, what kind of .....i can use? i use handbrake with dolby prologic II
thanks -
I was listening on some small speakers at low volume so I didn't hear the 60 Hz hum. You have a ground loop problem. Try plugging all the hardware into the same power strip. In the worst case you will need a ground loop isolator.
problem appears and disappears. sometimes you can hear it and sometimes not.
i will try changing plug
thanks -
And unplug any equipment/devices that you're not actively using. For example, cable TV cables are typically grounded very far from your house, making them a prime source of ground loop problems.
thanks jagabo for help.
today i did it, and video looks better, O_o and sound clear!!
but, why this happen?, i mean, i have same configuration in other room many electronics plugged to power strip , and in that case problem don't happen. -
You could try better shielded cables. This can happen if a cable is going bad making the ground connection intermittent. Make sure all AC plugs are plugged in the right way (modern plugs are all keyed so you can't plug them in backward). Make sure the AC plug in the wall is properly grounded and wired (you can get inexpensive testers for this: http://www.amazon.com/Electrical-Receptacle-Outlet-Ground-Tester/dp/B0012DHVQ0/). Try reversing any AC adpaters (wall warts) being used.
sorry im lost what cables? audio video or electric cables?
my problem is via composite rca cables (yellow, red,white) -
hi, i just check, funny in the morning signal looks good , afternoon back to problem.
im waiting to receive new cables, and if them not fix it, im considering buy this surge protector
Tripp Lite TLP74TG Eco Surge Protector Green Timer Controlled 7
http://www.amazon.com/gp/product/B0052NNRJG/ref=s9_simh_gw_p199_d0_i5?pf_rd_m=ATVPDKIK...pf_rd_i=507846
Best HD Directv Movie Capture settings for Hauppauge 1512 HD-PVR 2?
By raysurx2010 in forum Capturing and VCRReplies: 4Last Post: 12th Oct 2014, 00:02 -
audio/video noise for a second in some scenes
By jmrendo in forum Capturing and VCRReplies: 15Last Post: 28th Feb 2014, 05:56 -
Hauppauge Colossus recording in B/W DESPITE video filters
By artisticnstuff in forum Newbie / General discussionsReplies: 9Last Post: 25th Feb 2012, 15:32 -
Audio Noise on Vado when recording in car
By raticosa in forum Portable VideoReplies: 1Last Post: 10th Sep 2011, 19:34 -
Recording straight to MPEG2 PAL Video using a Hauppauge HVR-1800
By 3_2_DVD in forum Capturing and VCRReplies: 7Last Post: 22nd Sep 2009, 12:28
