First I am looking to spend not much more than $20 for speakers.
I've read quite a few post regarding this issue but have not seen one that seems to answer my question. How and What kind of speakers can be used externally for my 32 inch Vizio TV. I do not have a 3.5 audio jack but I do have a optical cable audio out jack. I do have standard RCA cable audio out ports. The optical cable , while a good idea does not seem to be available in other than a sound bar, which is pricey and to big. All the small speaker sets that are used with PCs need a 3.5 jack. I am looking for speakers that use RCA jacks but they don't seem available either. The only options seem to be some kind of converter, which are bulky . There must be some kind of very simple speakers for my set up but I have not been able to find them. Does anyone have suggestion?
red/white audio out ports are line level, not speaker level. you need speakers with an amplifier built in or a receiver and speakers.
Thanks. Not being to much of an audio buff, I am assuming that just regular pc speakers with power could not be used with the RCA out port. I could used a female splitter with those to plug into the RCa's?
i would think they would work. if they are stereo they should have red/white separate inputs.
I checked out the local pawn shop and bought some cheap bookshelf speakers that had been previously enjoyed, they worked out perfect. I did spring for a new Polk Audio sub-woofer for a $100. All in all, cheap setup that sounds great.
It's not important the problem be solved, only that the blame for the mistake is assigned correctly
Low cost LCD screens
By kkevin in forum ComputerReplies: 3Last Post: 28th May 2013, 10:39 -
Looking for low cost editor that can make multiple cuts and splice
By jimdagys in forum EditingReplies: 4Last Post: 11th Dec 2011, 12:33 -
Do I need a NLE & Is there a free/low cost one available?
By TBoneit in forum EditingReplies: 2Last Post: 17th Sep 2010, 12:08 -
Is nvidia 3d a low cost way to 3dtv?
By yoda313 in forum ComputerReplies: 6Last Post: 3rd Jul 2010, 01:35 -
Why can I get a low cost learning remote ?
By SingSing in forum Newbie / General discussionsReplies: 7Last Post: 27th Mar 2010, 20:35
