In virtualdub, using FFinputdriver, I can open my .mxf (YUV) files but even if I use the fast recompress, the uncompressed output is RGB (mediainfo report is a RGB), is there a way to output the same YUV as source?
You can force it by using video=>full processing mode, video=>color depth, input and output to 4:2:2 YCbCr (either UYVY or YUY2)
File=>file information should show mpeg2video 4:2:2 (it will say ffmpeg properties in the top left hand corner) . If it doesn't there is a problem with the import plugin, or you didn't use it properly (to be sure you need to select from drop down menu when opening video "files of type: ffmpeg supported files", otherwise you might be using another plugin to open mxf like directshow plugin)Last edited by poisondeathray; 26th Nov 2013 at 11:53.
VirtualDub Now Has a Directshow Driver Plugin
By Soopafresh in forum Video ConversionReplies: 57Last Post: 30th Dec 2013, 22:26 -
Virtualdub output
By DuBsTaR in forum Newbie / General discussionsReplies: 1Last Post: 7th Dec 2011, 13:53 -
Virtualdub 32bits error: cannot connect to the desired capture driver!
By Cauptain in forum Capturing and VCRReplies: 3Last Post: 21st May 2011, 12:17 -
VirtualDub Output question...
By nharikrishna in forum EditingReplies: 8Last Post: 22nd Nov 2010, 23:27 -
Output Files in VirtualDub
By Deter in forum EditingReplies: 9Last Post: 18th Jul 2010, 21:01
