Format : AVC
Format profile : Main@L3.2
Format settings, CABAC : Yes
Format settings, ReFrames : 3 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 30mn
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 30.000 fps
Original frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Default : Yes
Forced : No
Format : AAC
Format profile : LC
Codec ID : A_AAC
Duration : 1h 30mn
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
Compression mode : Lossy
Delay relative to video : 33ms
Default : Yes
Forced : No
i have serious issues with repackaging mkv containers to mp4 for xbox 360 playback.....
started with gotsent and the output files were 10 to 15 seconds out of sync..
then i tried xenonmkv and it was more succesful..every output file was now only 1-2 seconds out of sync..
so now i try using avidemux 2.6 and 8 times out of 10 when muxing the file to mp4 i get a error message saying video is too short..(also should be noted when avidemux does work the resulting mp4 file is flawless with no sync issues)
all i need to do is change the container to mp4 without touching audio/video...
any ideas?? and please no ffmpeg i'm new to all this...i have no idea how to use command line...
Results 1 to 14 of 14
here is one i did manage to mux to mp4 with avidemux:
Video
Format : AVC
Duration : 1h 34mn
Bit rate mode : Variable
Maximum bit rate : 40.0 Mbps
Height : 720 pixels
Frame rate : 29.970 fps
Color space : YUV
Bit depth : 8 bits
Default : Yes
Forced : No
Audio
Format : AAC
Format profile : LC
Codec ID : A_AAC
Duration : 1h 34mn
Default : Yes
Forced : No
basically identicle to the ones that avidemux doesnt seem to like??? duration being the only notable diffrence -
Frame rate : 30.000 fps Original frame rate : 29.970 fps
hey ok so..if i can find when the framerate changes could i split the video into 2 parts to fix this issue?? when i use avidemux and it says files too short...theres still an output file saved its just not the full video...so do you think it would work if i keep that file then try muxing the rest of the video separetly? if that makes any sense lol
sorry so remedial lol....... -
Format : Matroska
Format version : Version 2
File size : 1.99 GiB
Duration : 1h 34mn
Overall bit rate : 3 008 Kbps
Movie name : Rip by Mr. Drax http://rutracker.org
Encoded date : UTC 2013-11-26 06:18:58
Writing application : mkvmerge v4.0.0 ('The Stars were mine') сборка от Jun 5 2010 17:44:09
Writing library : libebml v1.0.0 + libmatroska v1.0.0
Video
Format : AVC
Duration : 1h 34mn
Height : 720 pixels
Color space : YUV
Bit depth : 8 bits
Default : Yes
Forced : No
Audio
Format : AAC
Format profile : LC
Codec ID : A_AAC
Duration : 1h 34mn
Default : Yes
Forced : No
this one here is the mkv of a file ive just repacked to mp4 in avidemux..and it actually saved (yes!)
and here is the working mp4 version of that same file:
Video
Format : AVC
Codec ID : avc1
Duration : 1h 34mn
Duration_FirstFrame : 67ms
Bit rate : 2 812 Kbps
Height : 720 pixels
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.102
Stream size : 1.86 GiB (93%)
Audio
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 1h 34mn
Bit rate mode : Constant
Bit rate : 192 Kbps
Stream size : 131 MiB (6%) -
and this is the mkv of a file that wont save correctly in avidemux
Format : Matroska
Format version : Version 4 / Version 2
File size : 1.85 GiB
Duration : 1h 30mn
Overall bit rate : 2 929 Kbps
Encoded date : UTC 2013-11-26 06:36:26
Writing application : mkvmerge v6.4.1 ('Omega Point') built on Sep 16 2013 22:05:10
Writing library : libebml v1.3.0 + libmatroska v1.4.1
Video
Format : AVC
Duration : 1h 30mn
Height : 720 pixels
Color space : YUV
Bit depth : 8 bits
Default : Yes
Forced : No
Audio
Format : AAC
Format profile : LC
Codec ID : A_AAC
Duration : 1h 30mn
Default : Yes
Forced : No -
Try a simple ffmpeg command. Put this in a batch file called "Remux to MP4.bat" and you can drag/drop video files onto it to remux into MP4.
Code:"c:\program files\ffmpeg\bin\ffmpeg" -i %1 -vcodec copy -acodec copy "%~d1%~p1%~n1.mp4" pause
convert h264 avi container to mp4 container
By azukich in forum Video ConversionReplies: 0Last Post: 6th Apr 2013, 16:09 -
MP4 container smaller than MKV?
By JamesWade in forum Video ConversionReplies: 4Last Post: 15th Dec 2012, 10:34 -
Cannot seem to convert MKV to MP4 or AVI to MP4 without audio sync issues
By Matth3w in forum Video ConversionReplies: 0Last Post: 16th Sep 2012, 13:36 -
need to put content of FLV container into MP4 container
By arraboy in forum Newbie / General discussionsReplies: 3Last Post: 29th Jun 2012, 19:52 -
convert mkv(2audio/2txt) to mp4 or other container
By felix in forum Video ConversionReplies: 3Last Post: 14th May 2009, 08:04
