Gents ... been following the posts above .... what is the final decision to run with the script as per post #135
or to incorporate any changes in the posts since that one ?
I will be as final step taking it into Vegas to try and fix some errors on initial part of video (mainly tranisitions & over dubbed music)
I could if you guys think it worthwhile invest in NEAT video plugin
Results 151 to 180 of 229
ADvise you to use Vegas with lossless media, then encode.
The scripts in #135 are the best I could conjure. You might throw something in there to get rid of even more aliasing, but there won't be any detail to watch. The final color tweak was in VirtualDub after the frames came out of Avisynth. Color is usually subjective for most people, so customize the color controls I used to suit what you want. Some scenes will require special treatment because color balanc changes constantly in those clips. What Avisynth did basically was try to make the wedding gown white. The rest was tweaked in VirtualDub.
IMO NeatVideo is essential for damaged tape. But use it very carefully; don't expect it to do everything. I used it as a final tweak in the videos posted, but it was turned almost down to nothing. Basically used as a sharpener because you can set it for high, medium, and low frequencies-- not easy to do with most sharpeners. Best way to use it is to add it last, only when necessary. And read the manual.Last edited by sanlyn; 19th Mar 2014 at 05:54.
I agree. I think the program tried to make neutral grey on the guys suit. It would probably need a Photoshop expert
to go further, and even if it's improved, doesn't really help with the video.
If you balance the colors to get the dress closer to neutral white, it looks as if the rest of the colors will
worse than they were originally. Surely it's because we're dealing with VHS color. It was always poor.Last edited by davexnet; 22nd Jan 2014 at 15:10.
It's an aged and poorly stored tape. The color has degraded quite a bit because the signal stored in the magnetic layer has deteriorated. It would be a real quest to make everything look "natural".
If you look at the script in post #35, there are some Avisynth statements that corect the bad offset with red and green. Early in the script:
Code:COlorYUV(cont_y=30,off_y=-7) COlorYUV(cont_v=-120,off_v=1)
Code:ConvertToRGB32(matrix="Rec601",interlaced=false) RGBAdjust(1.00, 0.92, 0.92,gb=-0.9)
I think you should post some suggested settings if Tafflad hasn't used it before. As you imply, most people use it at far too strong settings and destroy their videos. Doing nothing is far preferable.
Neither of us could win this argument without a time machine, but I bet that, apart from a few drop outs and creases (i.e. real physical damage), this tape plays back pretty much the same as it did on the day it was recorded. I bet the colours haven't changed one bit. Chroma is the most robust part of the magnetic signals on VHS tape, being recorded at the lowest frequency. Hi-fi stereo audio goes first. High frequency luma goes next. Tracking (damaged control track, right on the edge of the tape) goes most easily due to physical rather than magnetic damage.
What's changed are people's expectations, and the ability to pick faults. White = electric blue is ubiquitous in camcorder footage from that era, and that's how it always looked. That's how well the auto white balance circuits of the time (didn't) work.
Tafflad: do a bit, burn it to DVD, and watch it - before doing the whole thing. Burn a couple of different versions of that small section if necessary, maybe also including a version that just has the levels tamed a bit but no other processing (i.e. basically the original capture). Differences that look obvious on the PC are often lost on a TV.
Cheers,
David.Last edited by 2Bdecided; 23rd Jan 2014 at 05:15.
You are right I have never used this, don't mind investing in it.
Any tips, settings welcome. -
Agreed. It's somewhat like MCTemporalDenoise or QTGMC in that several functions can be enabled / disabled / tweaked; like those multi-function jobs you can use it to tweak a video or destroy everything in sight. Instead of a script it uses check boxes and sliders configured in a 2-window GUI. But if you save your settings in a .vcf file, you can copy the text of those settings into an AVisynth script. It's a combo filter with spatial and temporal components. The website at http://www.neatvideo.com/ is comprehensive. Unlike the text or html files that come with most Avisynth or VirtualDub plugins, its user guide is a 30-page illustrated PDF. The PDF for each version is a free download.
Getting into detail with NV is like trying to "explain" the details of QTGMC. You can view its interface and preview windows in default mode (and make mush of a video at those settings) or tweak the advanced interface, which the manual covers in great detail. A little time on their website answers many questions -- and of course just using the trial version answers many more in short order. I know of a couple of Avisynth plugins that work in a similar but scripted fashion: you specify a noise sample, then set up how much of that noise you want removed. Explaining here in a post would be tantamount to reproducing their whole website and manual, and makes it sound far more complex than it is in actual use.
I almost always set it at half-power or less. It also has a sharpener which internally runs after denoising. It's a pretty cool sharpener with several settings: the default is 100% power and can be set from 200% to zero. High settings give you something that looks embossed, so I keep it down around 50% to 20%. You can also turn it off, or turn off everything else and use the sharpener alone.
Filtering is divided into frequencies of high (very fine grain or eensty-weentsy detail) and medium and low-frequencies. The high-freq filter can do the most damage and is almost always turned down to a low 30% or less. Medium and low-freq noise would include the kind of clumpy, simmering grungy grayish muck that you see on an LCD when an analog source has movement. The residual background noise of analog and digital tape is where NV is most effective, and it can even spiff up mosquito noise and compression artifacts around edges. It's not very effective with stuff like rainbows. Usually, people specify 30-40% for fine noise, and around 60% for the "bigger" noise.
As I say, trying to explain it is a waste of time. The website demos and just using it for a short spell can quickly replace all the verbiage I just typed. There are some rather extreme demos here: http://www.neatvideo.com/examples.html .Last edited by sanlyn; 19th Mar 2014 at 05:55.
Each version of NeatVideo works only with the application you buy it for. You can't use it i9n Vegas and in VDub or something else unless you have the plugin version for each app. I have one for VirtualDub, one for AfterEffects. I consider it a waste of versions, as it's so much easier to use it in Virtualdub. I used it in AE only once, and could just as well have done it in VDub. The source has to go to lossless AVI anyway for use.
In your script it loads ContastMask.avs
Where do I get that from ? ...
Tried usual sites and it's not listed ... I found a ref that it can be used with Highlight limiter but not ContrastMask.avs as a download -
It's in the same post in the same thread...http://forum.doom9.org/showthread.php?t=161986
(which isn't stated in the wiki)
sanlyn - can't you just give him exact settings to try in the demo version? Then he can decide straight away whether to bother using it.
I have it (VirtualDUB version), and I only use it for specific problems. It's great for removing noise with some kind of pattern to it. Doesn't always work though. I can imagine the mid-frequency sharpening is useful here - but you really need to check this stuff on a TV rather than just on a PC. Don't use NeatVideo's temporal denoiser.
Cheers,
David. -
It's ContrastMask.avs. It's been used in the wedding scripts since November. It's included in a bunch of Avisynth plugins as an attached .zip file in post #33 (https://forum.videohelp.com/threads/360482-VHS-Family-Wedding-tape-restoration?p=228406...=1#post2284062). The .zip file is here: https://forum.videohelp.com/attachments/21516-1385842259/Scripts_and_plugins.zip.
The original doom9 post contains an error -- but I don't remember what it is!! However, the version I posted and used has the correction. Here's a copy of the corrected function:
Code:function ContrastMask(clip v, float "gblur", float "enhance") { enhance = default (enhance, 10.0) gblur = default (gblur, 20.0) enhance = (enhance>=0.0 && enhance<=10.0) ? float(enhance*0.1) : 1.0 v2=v.Tweak(sat=0) v2=v2.invert() v2=v2.gaussianblur(50.0,50.0+gblur) photoshop_overlay=mt_lutxy(v,v2,"x 127.5 > y 255 x - 127.5 / * x 255 x - - + y x 127.5 / * ? ") merged=overlay(v,photoshop_overlay,opacity=enhance) return merged }
Code:Import(drive:\path\to\Avisynth\plugins\ContrastMask.avs")
Code:ContrastMask(enhance=2.5)
Code:ContrastMask(enhance=6.0)
The "Highlighter" function you mention does the opposite: it's supposed to bring out highlights without blowing them away. A little more difficult to manage, though.Last edited by sanlyn; 19th Mar 2014 at 05:55.
I seldom use it nowadays. Sometimes you just "need" some noise, especially with VHS which is where a lot of "detail" really is. Of course there's always the case of just too much of it. But when it's needed, NV does do the job where nothing else will.
I think a sample noise file and settings were used somewhere in a thread on one of tafflad's clips, along with a sample of loading NV in Avisynth. I'll see if I can locate it.....
Hmm, I found something from another thread. Give me a while, I'll get up a demo of some sort using frames from something the O.P. has already posted. Will return a little later.Last edited by sanlyn; 19th Mar 2014 at 05:55.
Having some fun trying to get Step 1 to run ...
Found a missing line in the Highlighter.avs file ... needed to be a '}' after the last line.
Script reduced to attached .... currently stalling as I don't have plugin DeHalo_Alpha
I can't find that, most places I look seem to want me to download DeHalo_Alpha_MT2
but as your scripot calls for DeHalo_Alpha assume there is a difference.
Can you advise which version I need ? -
Oh, drat! Those { } brackets. I do that to myself more often than I care to admit.
DeHalo_Alpha must have been posted earlier somewhere, we've been using it evreywhere. I wish the powers-that-be would stop replacing on standbys. The MT version ought to work, but I haven't used it. The original is attached with its "old" html.Last edited by sanlyn; 19th Mar 2014 at 05:55.
Spent last couple of Hrs trying to get Step 1 of script to run .... my knowldege of Avisnyth is not good enough
Had a number of poUp window errors, managed to fix these. missing Plugin or path statements incorrect. etc.
But now I don't get a PopUp error window but get an error msg in bottom bar of VD. :
"Error reading source frame 0:Avisynth read error: ERROR: Invalid memory alignment"
This is the first script where you have used DirectShowSource
Previously you have used :
loadCplugin("D:\Program Files (x86)\AviSynth 2.5\plugins\ffms2.dll")
Is there something I'm missing to use DirectShowSource
aud = ffaudiosource(PathToVideo+"name.avi")
vid = ffvideosource(PathToVideo+"name.avi")
audiodub(vid,aud)
My script with local changes is attached -
The FFMS2.dll isn't a 'C' plugin. Remove the 'C' from the LoadCPlugin line. I don't know for sure if that'll fix it, but checking my template scripts (and I use FFVideoSource a lot), it's not loaded as a 'C' plugin.
And I don't use DirectShowSource for anything if I can possibly avoid it. You have the Chromashift plugin and the other filters you're using in the script? -
But FFMS2.dll isn't used in the script anyway, I was only mentioning that as a comparison.
I was just trying to look at previous scripts to find why it won't run and can see that this script uses DirectShowSource, whereas it has not been used in other scripts. -
Yes, but since you posted the script in the post, even though it's not in the uploaded script, I thought I'd mention it.
...can see that this script uses DirectShowSource, whereas it has not been used in other scripts.
Are you keeping it double-rate, or are you reinterlacing it later on? -
Certain versions of ffms2.dll are cplugins - the ones that have avisynth 2.6.x support and additional colorspaces like YV24 are cplugins
In your script :
Crop(22,2,-6,-14, true) -
It's deinterlaced in step one by QTGMC, this line:
QTGMC(preset="faster",Lossless=2, TR2=2,EZDenoise=2,sharpness=0.7)
Like manono suggested, I would replace DirectShowSource with AVISource(), if I were you . If that is a DV AVI - make sure you configure you decoder properly to output the proper colorspace -
Some VFW DV-AVI decoders like Panasonic's DV codec output RGB (this is bad because you will clip superdarks/whites, and the conversion to RGB usually isn't optimal)
To figure out what current VFW DV codec is being used on your system (and thus should be used for 32bit AVISource() in avisynth) , open up 32bit vdub, and load a DV-AVI file directly, check file=>file information .It should tell you what decoder is currently being used
Cedocida is recommended by many people . You should configure it to output YUY2 , disable the other formats. You may have to do some codec management with vcswap, depending on what other decoders you have installed -
[QUOTE=poisondeathray;2297383] Just did what you advise .. it is using CEDOCIDA
In the scripts its output using Lagartith YV12
I'll try changing to AVIsource - unless I hear from Sanlyn that there was a particular reason for using DirectShowSource
old VHS restoration
By pirej in forum RestorationReplies: 72Last Post: 30th Apr 2016, 07:26 -
VHS Restoration
By Asesinato in forum RestorationReplies: 239Last Post: 25th Apr 2012, 21:11 -
What am i doing wrong (VHS Restoration)
By Asesinato in forum RestorationReplies: 50Last Post: 14th Apr 2012, 06:02 -
old vhs restoration
By ishwinderjauhar in forum RestorationReplies: 16Last Post: 24th Sep 2011, 09:03 -
Some of my vhs restoration work
By henryperu77 in forum RestorationReplies: 3Last Post: 23rd Apr 2011, 00:24
