Hi, I feel as if this has been asked dozens of times, and I've searched all over this forum for an answer to my problem, but nothing has helped.
I'm trying to burn about 4-5 MKV file type episodes to a DVD for playback on my DVD player. I downloaded DVD Flick and all seemed good until I tested the converted files in a media player that plays dvd files. It was stuck on one picture and nothing else happened.
What do I need to do now? Any help would be appreciated.
Results 1 to 13 of 13
Hi, I tried that and I just get an error whenever I add my video file
"Warning! FrameRate value detected is invalid. Please insert it manually." -
Will I be able to watch these on a dvd player? That's what I'm trying to do.
Apparently his dvd player cannot handle mkv files and he is trying to make dvd-video.
Examine the mkv files with MediaInfo and see what it says about the framerate of each file. When you import the file into AVStoDVD you can right click on the video within the main window and get quite a few options, one of which is to Edit Source Title info. Putting your cursor on this gives even more options, one of which is Video Frame Rate. You can change the frame rate here manually.
And read your dvd player manual. See what types of video it can handle...different players have different capabilities. Not too many can play mkv files yet however. -
I tried this, and can not seem to even find the Frame Rate information for some reason. There is no option in MediaInfo to right click the video file, or either I'm over looking it.
Only thing that even mentions it is this
"FrameRate_Mode/String :VFR" -
The right click instructions are for AVStoDVD once the video shows up in the main window of that program.
Examining the files with MediaInfo gives you quite a lot of information about their structure. In this case, it looks like someone has made the files with variable frame rate (VFR), which may play ok, but is a tremendous pain in the ass to work with. -
If your are using HCenc in AVStoDVD you could switch encoders to ffmpeg. Don't know that it will make a difference.
You can try other conversion programs, notably ConvertXtoDVD and TMPGenc Mastering Works 5. There should be a free trial for the TMPGenc program. -
Responders are wasting their time. The O.P. has no idea what encoded format is involved and will not post MediaInfo data. Will check back at about this same time after Christmas to see if readers are still posting guesses.
Thanks for everyone's help. I tried a few different options in ConvertXtoDVD, and it worked like a charm. Plays perfectly in my DVD player and the quality is great.
Thanks again. -
For anyone looking. I agree with poster that convertxtohd does this well. It is not 100% as have had some issues with it: converted okay then instead of writing to disc, just stops, says conversion and writing completed succesfully then cant navigate menu. Gowever have also tried DVDFab and Leawo and have had better success with convertxtoHD.
Ive used version 3.07 to back up several MKv files, about 22g to blue-ray with a menu that is navigatablr.
Blu-ray to MKV w/ multiple subtitles, one is forced (burn-in) possible?
By louv68 in forum Video ConversionReplies: 18Last Post: 24th May 2013, 22:13 -
Burn multiple .uif & .img files onto 1 dvd
By rronald_25 in forum Authoring (DVD)Replies: 6Last Post: 29th Aug 2012, 15:15 -
Remove multiple tracks from multiple MKV files
By accoutabc in forum Video ConversionReplies: 3Last Post: 7th Aug 2011, 11:50 -
Merging/Converting Multiple M2TS files to MKV With Multiple Audio Tracks
By Nicholas S. Folsom in forum Video ConversionReplies: 1Last Post: 13th May 2011, 18:34 -
burn multiple video files on 1 dvd using ConvertXtoDVD
By sascha_ in forum Newbie / General discussionsReplies: 1Last Post: 31st Jan 2010, 06:09
