Is it possible to flash modified firmware on an LG BP620C? If so does anyone know of anywhere to find such firmwares? I'm guessing the answer is no since I've struck out finding any firmware in the usual places.
You're basically 10 years too late with this question. Back in the early 2000s some Chinese manufactured DVD players did have firmware modifications done for them. If there were any mods for major manufacturers like LG, there weren't many. The only modded firmware I've heard of in recent years was I heard of one Philips mod that was done specifically for Brazil to fix a problem with subtitles not showing all the possible accent marks in Portuguese. That's it. If you're looking for mods that do more than fix a subtitles issue, you'll need a time machine and probably a different DVD player.
I assumed there were modded firmwares to remove Cinavia detection
Blu-ray players that can be made multi region with modified firmware
By newgen2005 in forum DVD & Blu-ray PlayersReplies: 4Last Post: 5th Aug 2013, 14:48 -
how to put your voice or a modified one on a CD
By marlo in forum AudioReplies: 2Last Post: 23rd Apr 2010, 10:47 -
Modified subpic in menu?
By nandoc in forum Authoring (DVD)Replies: 7Last Post: 23rd Apr 2010, 10:44 -
modified oppo bdp-83 region free
By NicholasB in forum DVD & Blu-ray PlayersReplies: 1Last Post: 22nd Jun 2009, 12:35 -
Philips DVP5965k/98 modified firmware?
By chongbian in forum DVD & Blu-ray PlayersReplies: 4Last Post: 27th Nov 2008, 00:59
