Anyone know of an audio editor that can dither to 2-bit ? With a proper noise shaping method and subsequent pre-process filtering I could make 4-bit audio sound really good. I wanna see how far I can get with 2-bit.
i'm affraid that only Matlab with additional analysis pack... with such low resolution audio lot of new problems around nonlinearities appear (noiseshape dither level is comparable to signal level). http://csweb.cs.wfu.edu/~burg/CCLI/Templates/matlab_index.php .
http://www.hydrogenaudio.org/forums/index.php?showtopic=47980
Nope - SoX is not designed for this kind of operation - in fact SoX struggle with bit depth lower than 6 bits...
Once again 2 (or 1) bit is special case (as dither and noiseshape level is comparable to signal level itself) and special techniques are required to deal with it. -
@ pandy --- Thanks a lot for the additional info
Much to learn I still have :–/ -
I think that ability (and will) of learn is the most important part of our life! I mean this is most interesting part of being alive.
2 bit audio perhaps not very popular per se (however i can imagine that this can be beneficial for retro computing) but for example digital power amplifiers (like for example TacT Millenium and similar) exploit various low bit depth techniques (TacT for example SDM + low bit depth "NPWM").
MPC HC: 32-bit or 64-bit on Windows 7 64-bit
By flashandpan007 in forum Software PlayingReplies: 20Last Post: 22nd Jul 2016, 09:22 -
About Dithering/Debanding plugins
By zanaitoryoushi in forum Video ConversionReplies: 17Last Post: 29th Aug 2012, 13:56 -
64-Bit Vegas Pro 9 fails to open 64-bit UT Video Codec Pack
By Smells_Like_Feet in forum EditingReplies: 1Last Post: 2nd Oct 2011, 15:14 -
Avisynth's "levels" function - 32-bit? Dithering?
By Asterra in forum Video ConversionReplies: 7Last Post: 5th May 2011, 00:57 -
LAME 32-bit or 64-bit in EAC under Windows 7 64-bit?
By flashandpan007 in forum AudioReplies: 1Last Post: 12th Apr 2011, 09:40
